3 members (Hamwich, gomog, JohnHarris), 380 guests, and 83 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
I read an earlier exchange saying 40 to 45lb for shock upper and lower bolts. This still common wisdom? also, is there an official shop manual for 3W and if so, wonder if it could be made public in some way? through MTWC? Or is it already?
end user
no shop manual exists.
just make sure you have lock nuts
Manual.... we don't need no stinkin manual
Rodger
2004 Plus 8 (wife's)
i am pretty sure I witnessed a shop manual. but I am thinking of the x-wedge manual.
end user
MMC used some sort of individual tear sheets for the various procedures needed to maintain the M3W. As a problem arose they put out a sheet that could be kept in a notebook if I understood what was told to me.
The S&S Engine manual is very comprehensive and easy to follow and that includes following their videos.
Can you help tell me where these S&S videos are located?
Okay, I learned that it's about tightening it enough so that the shock does not move front to back (the parallel mounts should not be stressed by tightening together) which is held in place with the metal tube spacer located in the shock bushings. They need to be loose enough to allow play as arm moves up and down during driving. So... it's not about torque but about letting lock nut and spacer washer hold that bolt in place.
end user
use locktite or nyloc nuts and space with washers to take slop out of fit. With a micrometer all the shock mounts measure a different width.
i believe i got the videos from S&S website or youtube.
O
O
My understanding of these rubber bushed joints as used on the shocks and wishbones is that they should be packed with washers as necessary to avoid stressing the mounts but the bolts should be tightened up with the vehicle weight on them so the bushes are in a neutral position. If left loose you will get rattling and fretting at the joint.
Definitely this.
The inner tube of the bushes should be clamped solidly between the brackets to avoid the initial unconstrained movement that would result from them being free between the plates. Unfortunately, MMC designed the gaps between the brackets to be longer than the bushes so you have a choice of leaving the bushes loose which is really not good, tightening the brackets in so that they clamp poorly on the bushes due to them no longer being parallel (like MMC do) which isn't good as there will still be some movement leading to fretting of bolts and bushes or packing the gaps with washers so that the bushes are a tight fit between the parallel brackets then tightening the bolts. This is the best option with the original shocks and does reduce free movement.
At least some of the after market shock suppliers do supply their shocks with spacers that remove the excess gap but even then you will probably have to straighten the brackets to get the shiny new shocks in for the first time. After market shocks tend to have bearings top and bottom rather than bushes which is another good way of minimising free initial movement and friction as the loads change on the shocks.
