3 members (Hamwich, gomog, JohnHarris), 380 guests, and 83 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Dab of oppo #729195 03/01/22 07:47 PM
In a pinch we used 3/16" drill bits as the pins. 3 are needed. Put the car in gear with the brake off so as to make things go properly. Two bodies are a great help! Been There and Done That!
SeasideNick #729197 03/01/22 08:21 PM
Originally Posted by SeasideNick
Krazy Horse now have one less. My first annual service at just 850miles and KH found that the cam belt was cracked. A little worrying on a 12 month old M3W. I understand that the S&S wedge engine will not have damage if the cam belt breaks i.e, the valves won`t go through the pistons?? Can anyone confirm this ??
I can understand your concern.
It may be worthwhile grabbing a supply of belts while you can.
Stay safe
Dab of oppo #729253 04/01/22 05:46 PM
I bought two of those belts on ebay a couple of weeks ago. I joke that I'm going to wear them as a necklace when I drive around.
(S&S needs to step up....just sayin)
end user
Stevo666 #731734 30/01/22 11:24 PM
So how many "spares" do we need to carry ?
cam Belt , Regulator, Fuel pump ect Ect ?
2019 Audi TT RS
2015 Fiat 500 Abarth 595 Yamaha racing
2013 M3W
1974 MGB GT
Too many Bikes to list
Dab of oppo #731794 31/01/22 03:35 PM
JMD Offline
On long (eg mainland European) trips, we carry cam belt (& fitting kit), regulator, a fuel pump (now hopefully superfluous with the recommended upgrade to a Wabro one), some spare exhaust nuts and the rubber mounts for exhaust/regulator. Now we have done the wonderful Bleazey mod to the drivetrain, we could also take spare inserts for the centa-coupling.
Not all can be done at the roadside but better than being trailered home if one has the (hard to find but potentially vulnerable) bits required to fit at a friendly local garage as an alternative to a trailer trip home.
