8 members (IcePack, Grumpy2, JohnHarris, Scrambledsignals, MartO, nick w, Nickplus4, Luddite),
367
Topics49,904
Posts838,079
Posts: 358 |
I’ve had my one drop out in the past, I ordered a replacement from spares department at MMC. They will post it to you if requested Spares department don't have any in stock unfortunately. I managed to find an M10 Aluminium spacer 45mm long with OD of 19m on ebay which sounds about right.
92 Connaught Green Plus 4 Triumph Bonneville 865
Posts: 1,671 |
The screws are loctited into position which creates its own issues - regular check tightening is the answer
Posts: 22 |
When I bought mine, I found a secret checklist hidden under the leather panel on the dash from a previous owner. First stand out item on the list was - check fan bolts! I'm beginning to understand why it was on the list now
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
The screws are loctited into position which creates its own issues - regular check tightening is the answer Make sure when you remove the bolts that you use a flat bottom tap to clean the threads in the heads and a die to clean the bolts before you reassemble with more locktite.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I have always used Loctite 243 on the fan housing bolts and not had any problems with them coming loose or removing them when I have needed to. Not sure what the "issues" are Mark?
Posts: 365 Likes: 37
Posts: 365 Likes: 37 |
If you have JAP style rocker covers you need different size spacers and bolts.
Posts: 358 |
Thanks for all the feedback. EBay spacer arrived and fitted perfectly. I’ve loctited both sides now and will keep and eye of the bolts.
