7 members (RickyH, MartO, Sir Percival, JohnHarris, Rastus, Laurens, RichardV6),
342
Topics49,905
Posts838,099
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
![[Linked Image]](http://img113.xooimage.com/files/f/0/e/39230de1-6efd-4e...e7c9d93-58c828b.jpeg) 800 ° C at 3000 rpm
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Does the rear cylinder run hotter or colder than the front cylinder?
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I would doubt there would be much, if any difference because in the Morgan configuration there is no front/rear. on a motorcycle it would make a difference
I would doubt there would be much, if any difference because in the Morgan configuration there is no front/rear. on a motorcycle it would make a difference Driver side (USA) front cylinder as labeled by S&S. ![[Linked Image]](https://www.tm-img.com/images/2021/10/14/32DD07C6-1EB8-41F6-9097-38A89347E8B8_1_105_c.jpg) Rear cylinder or passenger side. ![[Linked Image]](https://www.tm-img.com/images/2021/10/14/D00E6E47-496C-4091-BC5D-FFCBC4E47073_1_105_c.jpg) Looks like a bit of burn difference, not great big difference but it is noticeable. I believe it has something to do with the angles of the intake manifold and therefore the length of the intake path.
Just discovered a possible reason for the increase in temperature on the front cylinder, a leaky exhaust valve. The rear cylinder was also leaking but nowhere near as badly as the front cylinder.
The rear cylinder is lightly colder 20° C
The rear cylinder is lightly colder 20° C Did you get the measurements from bungs welded into the head pipes?
