6 members (Jon G4LJW, John Winn, +8Rich, jbk, Chris Cosher, Pittsartist), 299 guests, and 23 robots.
+8Rich 101
John V6 62
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,195
Georgetoad, woolfie
Page 18 of 21 1 2 16 17 18 19 20 21
I would wait cutting it until you have the old pump out so you can compare and decide whats needed.
I was ready to cut mine , but found the new one fitted as supplied.
Good advice Nippymog. I think I’m going to find exactly the same.
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
Does it look like the one on page 3 of the detailed instructions? If not you may have to modify it "as required" to make it fit. Do you have the most up to date instructions? https://www.mtwc.co.uk/wp-content/u...l-pump-replacement-April-2020-update.pdf
I recently replaced my OE fuel pump with the Walbro unit and found I didn't need to reduce the entire height, only to trim ever so slightly at one? end to have it sit flush.
Another THANKS for the instructions!
'17 M3W (BRG)
'03 Plus 8 35th Anniversary (BRG)
'08 Ural Patrol (BRG)
'21 Vespa 'Racing 60' (BRG)
Well it looks the same but the base of the foot is only 6mm so all I can slice off are the bits protruding from the top of it. That is what confused me and still does if I’m honest.
Actually now I’ve looked at it again it is only the 6mm at the bottom I need so it becomes clearer. I’ll sort it once I start the job.
Bunny Offline OP
If the rubber part you've been sent looks different to the one in the instructions then would you be able to take a couple of photos so that we can update the fitting instructions? It's possible that Glencoe are using an alternative rubber foot after some people reported that the old type swells up when in contact with fuel. doh
Thanks!
Andy
I don't think this is anything amazing. I find that I have been swelling up with age and extra fuel as well. I think this is more common than you think.
laugh2
Craig - Texas, USA
2026 Plus Four
2021 M3W
Thanks!
I have pm'd you
Bunny Offline OP
Here are Jonathan's photos of the newer type Walbro rubber foot:
It does indeed appear that it will end up at around the right thickness if just the protuberance is cut off.
Andy
