6 members (Graham, G4FUJ, Strathaven, TBM, ITP, Tresco, banbury), 235 guests, and 39 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,110
#730422 17/01/22 07:04 PM
800 ° C at 3000 rpm
Does the rear cylinder run hotter or colder than the front cylinder?
I would doubt there would be much, if any difference because in the Morgan configuration there is no front/rear. on a motorcycle it would make a difference
Rodger
2004 Plus 8 (wife's)
Driver side (USA) front cylinder as labeled by S&S.
Rear cylinder or passenger side.
Looks like a bit of burn difference, not great big difference but it is noticeable.
I believe it has something to do with the angles of the intake manifold and therefore the length of the intake path.
Just discovered a possible reason for the increase in temperature on the front cylinder, a leaky exhaust valve. The rear cylinder was also leaking but nowhere near as badly as the front cylinder.
The rear cylinder is lightly colder 20° C
Did you get the measurements from bungs welded into the head pipes?
Yes
