8 members (RickyH, BobtheTrain, RichardV6, Mike D, Sir Percival, Image, JohnHarris, MartO),
252
Topics49,905
Posts838,100
Posts: 731 Likes: 58
Posts: 731 Likes: 58 |
I have had problems with my fuel gauge not reading the correct amount in the tank. At first I thought it might have been the sender in the tank not working, due to the tank being empty for 2 and half years. But after putting a volt reader it was decided that the problem was the electrical regulator behind the dashboard. Alas having changed the regulator the fuel is reading correct but the Coolant temperature gauge is now reading very high. The Coolant is Evans waterless. I'm scratching my head on the as the regulator controls both gauges. Has anyone in TM world got any ideas to fix this. I have tried changing the connections at the back of the water gauge with no change. As normal any help in the matter is greatly appreciated.
Navy Dave 1976 Morgan 4/4
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Could it be that the the regulator change that sorted the the fuel gauge has now also"sorted the temperature gauge and in fact that is the correct reading.
Waterless coolant can make some systems run hotter if they were marginal in the first place.
What is the gauge reading and have you checked it by putting the sensor in just boiled water. Maybe the gauge is correct.
Could be you have a cooling problem rather than a gauge problem.
Bob
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Having trashed a new sensor by doing just that, it seems thermal shock can have a negative effect (as the chap told me when I complained..). The best way is to pop it in water at room temperature and heat gently..
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Check the earth connection to the gauge
Posts: 8,700 Likes: 416
Posts: 8,700 Likes: 416 |
I have had problems with my fuel gauge not reading the correct amount in the tank. At first I thought it might have been the sender in the tank not working, due to the tank being empty for 2 and half years. But after putting a volt reader it was decided that the problem was the electrical regulator behind the dashboard. Alas having changed the regulator the fuel is reading correct but the Coolant temperature gauge is now reading very high. The Coolant is Evans waterless. I'm scratching my head on the as the regulator controls both gauges. Has anyone in TM world got any ideas to fix this. I have tried changing the connections at the back of the water gauge with no change. As normal any help in the matter is greatly appreciated. You don't mention what voltage is/was provided to instruments Dave. Should be 10 volts WRT instrument ground. Sensor grounding is most important as well particularly in the case of fuel gauge circuit. Recommend solid state regulator BTW.
Posts: 172 |
You don't mention what voltage is/was provided to instruments Dave. Should be 10 volts WRT instrument ground. Sensor grounding is most important as well particularly in the case of fuel gauge circuit. Recommend solid state regulator BTW. Richard, Many thanks for the recommended link, I was not aware of these solid state versions, I feel another preventative modification coming on!
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
You don't mention what voltage is/was provided to instruments Dave. Should be 10 volts WRT instrument ground. Sensor grounding is most important as well particularly in the case of fuel gauge circuit. Recommend solid state regulator BTW. Richard, Many thanks for the recommended link, I was not aware of these solid state versions, I feel another preventative modification coming on! I've used one - made my fuel and temp gauges far more accurate.
Posts: 463 |
Just what I needed another job for my winter project list. Thanks.
Dave 98 +8 Corsa Red 74 MGB Red
