1 members (Ian Wegg), 253 guests, and 22 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
DaveK Offline OP
I have had problems with my fuel gauge not reading the correct amount in the tank. At first I thought it might have been the sender in the tank not working, due to the tank being empty for 2 and half years. But after putting a volt reader it was decided that the problem was the electrical regulator behind the dashboard. Alas having changed the regulator the fuel is reading correct but the Coolant temperature gauge is now reading very high.
The Coolant is Evans waterless. I'm scratching my head on the as the regulator controls both gauges.
Has anyone in TM world got any ideas to fix this. I have tried changing the connections at the back of the water gauge with no change.
As normal any help in the matter is greatly appreciated.
Navy Dave
1976 Morgan 4/4
Could it be that the the regulator change that sorted the the fuel gauge has now also"sorted the temperature gauge and in fact that is the correct reading.
Waterless coolant can make some systems run hotter if they were marginal in the first place.
What is the gauge reading and have you checked it by putting the sensor in just boiled water. Maybe the gauge is correct.
Could be you have a cooling problem rather than a gauge problem.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
SBM Offline
Having trashed a new sensor by doing just that, it seems thermal shock can have a negative effect (as the chap told me when I complained..). The best way is to pop it in water at room temperature and heat gently..
Check the earth connection to the gauge smile
You don't mention what voltage is/was provided to instruments Dave. Should be 10 volts WRT instrument ground.
Sensor grounding is most important as well particularly in the case of fuel gauge circuit.
Recommend solid state regulator BTW.
Richard,
Many thanks for the recommended link, I was not aware of these solid state versions, I feel another preventative modification coming on!
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
TBM Offline
Richard,
I've used one - made my fuel and temp gauges far more accurate.
Just what I needed another job for my winter project list.
Thanks.
Dave
98 +8 Corsa Red
74 MGB Red
