1 members (RichardV6),
298
Posts837,278
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
Of course the more discerning Morganeer with wire wheels will be running polished Aluminium brake drums..? https://www.brakedrum.co.ukIf I I remember correctly, in times past the GoMoG webmaster used much modified and highly polished Datsun 240Z (?) finned alloy rear brake drums on his +8 gleam machine..
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Like Dave I use a standard spray aerosol after rust treating.
Posts: 2,583 |
Thank you all - I think I shall go down the Smoothrite route as I`ve used it before on other things and also have some in dark green already.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
A rattle can of satin black engine enamel when new & they still look great
Of course the more discerning Morganeer with wire wheels will be running polished Aluminium brake drums..? https://www.brakedrum.co.ukIf I I remember correctly, in times past the GoMoG webmaster used much modified and highly polished Datsun 240Z (?) finned alloy rear brake drums on his +8 gleam machine.. Look great, but when I last enquired when they had a stand at the NEC, something around £500 the pair...I had to shuffle off for a strong cup of Yorkshire tea and a sit down
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
I wonder why someone doesn't make some thin spun aluminium or stainless covers for brake drums? .... would be cheap as chips (or at least as cheap as a pound-shop saucepan 🙂) to make.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
It's been done, but not sure if it was Morgan. May have been for MGB.
Seems a shiny solution to an irritation for wire wheel users ... would cost pennies each to spin .... and such is the love of shiny things in the Morgan world that if you lasered a set of wings on it there'd be a queue at 50 quid a pop !! 🤣
Posts: 396 Likes: 44
Posts: 396 Likes: 44 |
I could've knocked you a them up........ a number of years ago..... ![[Linked Image]](https://iansharples.uk/wp-content/uploads/2018/03/spinner-768x617.jpg) Used to spin wheel trims for a couple of Messerschmitt's owned by 2 guys in the maintenance dept (along with many other "foreigners" (bell mouths for Honda 400/4's was a regular))
Ian S
2019 Sports Green Plus 4 2025 Hyper Blue Mercedes 180 CLA
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I don't think the rears generate much heat. Unless you are racing!
