Posts837,277
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Éthanol kit ![[Linked Image]](http://img114.xooimage.com/files/4/5/d/6b133580-2c5f-46...940fa57-58d10df.jpeg)
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Allow to run with éthanol
Have you noticed any different in the way the big twin runs? Improved mileage?
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Allow to run with éthanol Why wouldn't it run with Ethanol before?
Allow to run with éthanol Why wouldn't it run with Ethanol before? Thats a good question Steve. We have 10% ethanol and it runs fine although I suspect it might run better without it. I wonder if adding another path for the fuel to run through the catalyst does anything to the ECU?
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
The red gasket on the longer level sender might not like ethanol...I've recently replaced a completely rotten one with a Viton gasket. I'll guess that you are going to E85 or maybe even 100% ethanol.
