Well, eventually after another delay for a new rear wing I made it down and got it fitted.
There are a few options for the Control Pad, I opted for a pad mounted on the dash below the Start button.
![[Linked Image]](https://www.tm-img.com/images/2022/02/10/DSC_0006_edited.jpg)
The computer for the unit is fitted nicely into the fuse box on top of the BCU and ECU.
![[Linked Image]](https://www.tm-img.com/images/2022/02/10/DSC_0011_edited.jpg)
An additional sensor was required for the Clutch so that the cruise control is paused when the clutch is operated. As you can see a bracket had to be attached to mount it.
![[Linked Image]](https://www.tm-img.com/images/2022/02/10/DSC_0012_edited.jpg)
Operation is just like all normal cruise controls. I used it extensively on the drive back north and it works as it should.
It's not as sophisticated as OEM units I have experience of. I can feel the car being kept at the selected speed, a bit of acceleration then backing off on a regular cycle which is more noticeable on inclines, which makes sense as the car will slow down faster and need more acceleration.
The whole thing took over 5hrs to install and cost £660 from
http://www.motormods.co.uk/ who I have no association with. The installer said adjustment of the unit was tricky because the accelerator is a hair trigger.
