8 members (B3MOG, TBM, Doug J, Dek, MJF, Guern, Ian Wegg, Bunny),
223
81
Topics49,861
Posts837,531
Posts: 22 |
Hi everyone, I thought I had put a question on the forum, but I cannot see where it has gone!!. Never mind I'll do it again, sorry if you see it twice!! I have a 1997 Plus 8 4.6ltr I have been looking with interest at the big black plastic container in the engine compartment situated on the passenger side rear in the engine compartment. This has something to do with fuel vapour capture from the fuel tank and I believe helps with fuel emissions and reduces fuel smells from the excess vapour. This device is connected to the vacuum side of the air box and connects to the vent on the fuel tank. There is an electrically controlled valve that I imagine opens at some time to allow the excess fuel vapour into the airbox. Does anyone know much about this device? What triggeres the valve to open, is it something to do with the ECU? I cannot see much info on the internet about this! Thanks all. Martin
1997 +8 4.6ltr, MX5 ND 2.0Ltr Rover Sterling 2.7ltr Touareg 3.0Ltr
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Sounds like an charcoal filter or canister. The charcoal absorbs the petrol vapours . The solenoid valve opens to allow the vapours to burn once the engine is warm & over a set RPM. The ECU controls that. http://blog.widiyanata.com/en/autom...ter-functions-pictures-and-how-it-works/
Posts: 1,415 |
Hi everyone, I thought I had put a question on the forum, but I cannot see where it has gone!!. Never mind I'll do it again, sorry if you see it twice!! I have a 1997 Plus 8 4.6ltr I have been looking with interest at the big black plastic container in the engine compartment situated on the passenger side rear in the engine compartment. This has something to do with fuel vapour capture from the fuel tank and I believe helps with fuel emissions and reduces fuel smells from the excess vapour. This device is connected to the vacuum side of the air box and connects to the vent on the fuel tank. There is an electrically controlled valve that I imagine opens at some time to allow the excess fuel vapour into the airbox. Does anyone know much about this device? What triggeres the valve to open, is it something to do with the ECU? I cannot see much info on the internet about this! Thanks all. Martin The valve is triggered at cold start or when at full throttle when a rich mixture is needed
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Have a look in gomog in the Plus8 specific section. There are details in there of the efi systems used.
Simon, I was quoting from the Haynes manual I have for my Ti6 +4. See point 7. I guess it varies by ECU engine etc John
Evaporative emissions control 6 To minimise the escape into the atmosphere of unburned hydrocarbons, an evaporative emissions control system is fitted to models equipped with a catalytic converter. The fuel tank filler cap and vents are sealed and a charcoal canister is mounted in the engine compartment to collect the petrol vapours generated in the tank when the car is parked. It stores them until they can be cleared from the canister via the purge valve into the inlet tract, to be burned by the engine during normal combustion. 7 To ensure that the engine runs correctly when it is cold and/or idling, and to protect the catalytic converter from the effects of an over-rich mixture, the purge valve is not allowed to open until the engine has warmedup, and is under load; the valve is then opened to allow the stored vapour to pass into the inlet tract. 8 On 4-cylinder engines the vacuum supply to operate the purge valve is regulated by a purge control valve solenoid which itself is under the control of the ECU. The solenoid is mounted either separately within the engine compartment or, on later models, directly on top of the charcoal canister. 9 On V6 engines the vacuum supply to the purge valve is regulated by the constant vacuum control valve (under ECU control) and by a thermostatic valve which is opened or closed depending on coolant temperature
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
That all sounds logical and comprehensive despite coming from a Haynes manual John
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
John That’s exactly how the Advanced EVAP worked on my 2002 +8. After enthusiastic overfilling by a petrol attendant in France and a morning of splutter and cut outs (plus me in panic mode) I managed to clear it but wanted to analyse how and when it worked.
The GEMS system supplied an Earth to the constantly (ignition on) fed purge valve, I lashed in an LED test lamp and can confirm it did not operate on cold start up and had nothing to do with enrichment as that was done by widening the injection pulse width as seen on an O’scope engine analyser.
The purge valve was energised when the coolant temperature reached 80-82 degrees AND the throttle signal was more than 15% above idle. I fed this data back to David Ashley-Poole who I knew well at that time and I believe he included it in his magnificent GEMS manual.
I learnt not to overfill the car as the carbon EVAP canister was in the rear alongside the fuel tank and very difficult to bypass the ECU and manually purge!
BR Colin
I had an idle issue with my t16 which is why I know. The purge valve had failed I thought. Turns out it was the ecu.
Posts: 22 |
Ah, now that makes a lot of sence, I thought it must have been related to a combnation of engine temp and throttle position, as it is shut off when I first run the engine. But as this is a very early model injection system, it seems pretty basic, so I wanted to understand what sensors trigger the purge valve device. I will also fit an LED to see what happens with the purges valve, as I have a feeling that the valve occassionally does not shut off correctly, as sometimes (rarely now!) I have a stalling issue which annoys me. When I bought the MOG in 2016, I had all kinds of issues which I repaired one by one (as we all do). The most annoying issue was an occassional stalling at idle, I tried all the usual things to try to resolve the stalling issue, IE checked for (and found) vacuum leaks, checked vacuum advance, cleaned and later replaced the idle control valve, replaced the throttle potentiometer (TPS), replaced the mass air flow meter and set up the idle speed on the throttle body. I also fitted new injectors and rechipped the ECU. After all this work the idle stall problem improved greatly and no problems for 3k miles. But returning from the NC500 last year it stalled again!!! AAAAHHHHH. So either the idle control valve needs a clean again or maybe its the EVAC purge valve. Any ideas?
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
Have you checked the earth on the road speed sensor? I had a similar issue on my 94 +8, it started by on occasion stalling when coming to a halt and progressively got worse over time. On locating the road speed sensor I found it had become loose from the bulkhead and not giving a good earth, cleaned up the bolt tightened and never had the problem since. If the road speed sensor is not functioning correctly when the car is coming to a stop the ECU does not react quickly enough to the slowing of the vehicle which the sensor would tell the ECU and hence it can stall.
