Topics48,340
Posts812,969
Members9,203
Posts: 22 |
Out of interest roughly how much is the disk conversion kit?, or is an item that M3W services don't sell independent of fitting? Also, does it change the F/R brake balance?
Posts: 45 |
I have all of that on the Bleazey Special bar braided oil pipes. I already have G56 Stage 1 I’ve booked a disc brake with Craig. Ive also added LED headlights, which are a must if night driving. When you’ve done it all don’t forget to get your car revalued! I have lots of other stuff waiting in the wings but none as important as already mentioned.
The Bleazey Special.
Posts: 65 |
Ian, the brake disc conversion is £1300 fitted.
Craig at the moment will not supply the kit to fit yourself.
Yes the front brakes will need balancing to the new rear disc.
2019 Audi TT RS 2015 Fiat 500 Abarth 595 Yamaha racing 2013 M3W 1974 MGB GT Too many Bikes to list
Posts: 65 |
Morning No 42 Thanks for the reply.
Yes i fitted LED's a soon as i got back from a night trip just after i bought it.
As for the stage 1, whilst its in for thee other work he is drilling out my standard pipes ----------the stage one is a bridge too far with the amount of money i'm spending.
cheers
Chris
Posts: 65 |
Just to add the fitting of the disc conversion is £1300 plus the Dreaded VAT
Posts: 22 |
Thanks for that Chris! I'll stick it on the wish list, rather than the todo list for the moment
Posts: 365 |
In addition to all of your other good stuff maybe throw a set of ohlins and those fancy Turrino wheels/rims in as well. The wheels are tubeless so easy to plug if you have a bit of a mishap on the road.
2017 M3W Sport Green
Posts: 65 |
2 Sharp,
With the amount of money i'm spending / spent this year i think i will put those on the back burner.
Concentrating on reliability areas first.
Cheers
Chris
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
In addition to all of your other good stuff maybe throw a set of ohlins and those fancy Turrino wheels/rims in as well. The wheels are tubeless so easy to plug if you have a bit of a mishap on the road. And besides more easily fixed alongside the road somewhere they do not flex as much as the wire wheels. ![[Linked Image]](https://www.tm-img.com/images/2022/02/23/IMG_1258.jpg) Not sure if I am going to put the pinstripe on them or just paint them. ![[Linked Image]](https://www.tm-img.com/images/2022/02/23/IMG_1256.jpg)
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Very smart  You'll enjoy cleaning them, I know I do mine
