7 members (RichardV6, JoeSpeetjens, Zach, Clipper, Morganmike, DCH, teknome), 371 guests, and 97 robots.
+8Rich 78
DaveW 52
Topics49,867
Posts837,612
Page 9 of 9 1 2 3 4 5 6 7 8 9
P Dron #735690 11/03/22 02:14 PM
Can you not just remove the hub from the wheel and get it balanced, I think that is what most do
P Dron #735694 11/03/22 02:57 PM
I have a static balancer that I used to use when I raced bikes. Does a good job and yes it does make a difference having tried an unbalanced tyre.
P Dron #735695 11/03/22 03:01 PM
I have replaced several worn back tyres on my M3W and never had them balanced, it's not been a problem. You can buy a bubble type balancer kit and some stick on weights from eBay for about £60. They work well for the front wheels as well if you cannot find a tyre fitter with the correct cones for wire wheels to fit a dynamic balancer
http://smoothridecones.co.uk/, get your prefered tyre fitter to buy a set, or get one yourself
06 Saab 93
P Dron #735791 12/03/22 05:34 PM
+1 for Dynabeads, they work a treat.
But presumably if you use them in the rear tyre you can't also use Punctureseal or similar?
I wouldn't run my rear tyre without some form of puncture sealant given the seriousness of a rear wheel puncture on the M3W.
Red Leader drive
P Dron #735854 13/03/22 11:46 AM
The balance weights on my rear wheel fell off when the paint peeled. If I had not found them on the garage floor I would likely never have noticed
Chris99 #735881 13/03/22 02:18 PM
[quote=Dab of oppo]+1 for Dynabeads, they work a treat.
Now that is a very good point!
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
P Dron #735895 13/03/22 04:41 PM
Sorry, not enough clarification.
Dynabeads in the front and puncture seal in the rear. My local tyre fitter had no problem dynamically balancing the rear rim. It fitted on his machine without a problem.
P Dron #735904 13/03/22 06:31 PM
Yep agreed. I have Dynabeads in the front tyres and they are very effective and have the puncture seal in the rear. I forgot myself when suggesting using the beads in the rear. They would work but the puncture seal is far more important
