9 members (DCH, flyfisher, B3MOG, Chris Cosher, DJC, TBM, auster, John V6, sprinty),
245
Topics49,914
Posts838,185
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I talked to Gott and Wynn about this issue. Their advice is don't lock the car, especially with the hood up. A new car radio is less than the insurance excess on a claim and a slashed roof is a large and inconvenient claim.
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
My Plus Four is exactly the same, it locks the doors outside but you can open them from the in side, mind you, every new car is the same. Thats a good point - if I lock my Corsa with the central locking you can open it from the inside with just the door handle. Not tried locking it with the key. Just tried with the key - can't open from the inside if you lock the door with the key. So it sounds like the Plus Four is standard operation.
Posts: 37,490 Likes: 994
Posts: 37,490 Likes: 994 |
I talked to Gott and Wynn about this issue. Their advice is don't lock the car, especially with the hood up. A new car radio is less than the insurance excess on a claim and a slashed roof is a large and inconvenient claim. That is the logic I have always applied and never locked them. I'm OCD with the tin tops though
Posts: 3,701 Likes: 135
Posts: 3,701 Likes: 135 |
... you can then slide the window back reach inside and unlock the doors via the interior handle - very safe! No exterior locks or even handles on my car so that is the procedure, an arm through the window is the way in. (I've often had people watch me do it but I've never been challenged!) Curiously there are actually locks, operated by flicking a little tag next to the interior handle. I'm not sure of the purpose.
Posts: 12,268 Likes: 323
Posts: 12,268 Likes: 323 |
I use mine as a check to make sure my doors are properly shut. They have been known to swing open on particularly bumpy corners when taken enthusiastically if not fully shut.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Curiously there are actually locks, operated by flicking a little tag next to the interior handle. I'm not sure of the purpose. [/quote]
Those internal lock toggles allow you to lock the doors so you don’t get robbed when you stop at traffic lights for instance. I also make use of them to ensure that the doors are fully closed before we set off. If you don’t pull the door hard enough it looks to be closed but only holds on the first catch which can easily let the door fly open when you go round a corner. In that case, the lever will only go half way round the quadrant, whereas when the door is securey shut, it will reassuringly go the whole way. We regularly adopt this procedure as part of pre flight checks.
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
My Plus Four is exactly the same, it locks the doors outside but you can open them from the in side, mind you, every new car is the same. Thats a good point - if I lock my Corsa with the central locking you can open it from the inside with just the door handle. Not tried locking it with the key. Most 'blipper' operated central locking requires a 2nd blip, the first just locks, the second deadlocks so thieves breaking a window can't pop the door open from the inside door latch Have the CX owners tried the 2nd blip technique ??
Posts: 8,703 Likes: 416
Posts: 8,703 Likes: 416 |
I wonder what current Insurers T&C's say ? Surely central locking is just a gimmick on any soft topped Morgan from the security point of view. Any Morgan insurance specialist isn't going to be the least concerned about the subleties of its working given the Classics don't even have such.
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
It is worth asking your insurance company how you stand on door locking and alarms.
Some have a policy that states that if doors are unlocked they void cover. (Yet they cover a soft top....)
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Not sure, in 18 years of Morgan's I've never locked one the way I see it saves a slashed cover or roof leaving it unlocked. It's all about your own comfort zone though and where you live and or park up I suppose. I have done that with the boat but never with the car since I suspectt it would void any claim for theft. Ask your insurance company - it would be interesting to hear what they said.
