Topics49,843
Posts837,335
Posts: 12 |
I use Tomtom vio, it's originally made for scooter, but it fit very well the 3 Wheeler! ![[Linked Image]](https://imagizer.imageshack.com/img924/5530/dgf3Jp.jpg) But the Rammount solution showed here is very nice! I will may be also use this with an iPad mini 2 I just have back.
Posts: 131 |
I'm resurrecting this thread to ask if anyone has experience with vibration damaging their iPhone' camera and or with the Quad Lock and its Vibration Damper as a solution.
'17 M3W (BRG) '03 Plus 8 35th Anniversary (BRG) '08 Ural Patrol (BRG) '21 Vespa 'Racing 60' (BRG)
Posts: 32 |
@MichaelS I use the SPconnect system. I have the regular screen mount in my normal cars and their “clutch mount pro” mounted onto the usual dash retaining hex bolts without any mods. It looks smart (black on black) and the angle can be adjusted perfectly to be completely square to the driver but out of the primary eye line for driver and passenger. I went for the anti vibration module but not to convinced it does much. Everything shakes so much! Google maps is still clearly visible including the small print though https://sp-connect.co.uk/products/clutch-mount-proI could send you photos if you let me know your email. I still can’t attach on here it’s just not intuitive.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Posts: 131 |
Thanks for the ideas, guys. Reason for asking.....
I recently bought a BMW K1600 with a Navigator V GPS (integrated comm' system) and am considering how to leverage components into the 3W. One option is to buy a second Nav V mounting/power system for use in the 3W and signal-permitting, to wedge it in the on the center console under the dash. Otherwise place it onto the dash as Lightspeed has done.
a Simpler solution is to use only my iPhone/earbuds for navigation/music with a ball mount-->3" extension-->Quad Lock' vibration damper--> QuadLock/Charging pad installed on or under the dash that I swap between the bike and 3W. It's the spirited vibration at idle that has me concerned about the iPhone. Functionally this is the more elegant solution.
Posts: 99 Likes: 5
Posts: 99 Likes: 5 |
M3W 2017 Sport blue.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
I'm a hard of hearing old Coot so I use my Bluetooth hearing aids connected to my iPhone which works a treat.
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
I'm resurrecting this thread to ask if anyone has experience with vibration damaging their iPhone' camera and or with the Quad Lock and its Vibration Damper as a solution. Given Apple's warning about vibration from high-powered motorcycle engines damaging modern iPhones, I would not mount my iPhone on my M3W. The S&S engine delivers world-class shaking as we all know. A vibration damper would need to be extraordinarily effective to dampen that, and it would be an expensive experiment to run if a damper is not effective!
2020 M3W
Posts: 36 Likes: 3
Posts: 36 Likes: 3 |
A number of people do this ![[Linked Image]](https://i.imgur.com/XgdRrqc.jpg) ![[Linked Image]](https://i.imgur.com/f14bjn5.jpg) Long headless bolt - notched plastic ball (TomTom size; larger for Garmins). Are you satisfied with this solution? I installed this RAM mount for my Garmin Zumo. I use my Garmin in my Morgan and on my Kawasaki motorbike and in various rental cars. Only on my Morgan I notice poor GPS precision whenever I am between mountains or high buildings. On flat terrain it works fine - as ususal. I suspect that the metal dashboard blocks half of the sky so that the Garmin can't calculate a good position fix. An external antenna might help, but I haven't tried it yet.
2016 M3W
