9 members (sewin, Jon G4LJW, linklaw, nick w, MATTMOG, Mogdavid, High Hamster, Grumpy2, bmgermany),
192
37
Topics49,901
Posts838,041
Posts: 535 Likes: 1
Posts: 535 Likes: 1 |
This is the stuff that Brand Hatch Morgan use and said that should be used in these BMW V8s. A quick "Google" and I found it easy to get online. ![[Linked Image]](https://www.tm-img.com/images/2021/11/24/FCD454EF-D0ED-4C8A-B4A7-F9E095BB94A6.jpg)
Cheers, Paul
Posts: 8,698 Likes: 498
Posts: 8,698 Likes: 498 |
Before someone points out colour is not always proof of what specific version of antifreeze it is...BUT that blue stuff above that only has a 2 year life is pretty basic 'trade' quality, you need to see the small print on the can to check it's BS spec
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Before someone points out colour is not always proof of what specific version of antifreeze it is...BUT that blue stuff above that only has a 2 year life is pretty basic 'trade' quality, you need to see the small print on the can to check it's BS spec Looks like it's the basic IAT Autochem ABL001 Blue 2 Year Antifreeze
This concentrated 2 Year Antifreeze is a methanol free formulation suitable for all engine types, providing exceptional all year-round protection and performance, in all driving conditions. Contains anti-corrosion additives, allowing it to inhibit rust within the system for a maximum of 2 years. Suitable for use in many Classic/Vintage vehicles.
SPECIFICATIONS
Manufactured to meet BS6580 (2010).
VERY basic stuff, not much better than the Blucol I used to flog in the '70's
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I see there are newish formulations compatible with both IAT and OAT based antifreeze. I suspect that MMC uses the cheap stuff... next service I'll get the system drained and refilled with OAT Longlife antifreeze/coolant.
Posts: 69 |
Peter I'm pretty sure this is what's in my car Mannol long life Seems to tick all the boxes...
2016 Aero 8 S5
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Used the same stuff in my Roadster after fitting SiFab rad. A bit of research revealed it was up to the job. Found source on eBay.
Although described as concentrated to -40°C protection it's designed to be used neat. Factory coolant drained out tested to same freezing point.
Posts: 1,341 Likes: 15
Posts: 1,341 Likes: 15 |
There's a case for waterless coolant, pro & con article hereOn a car you plan to keep, faster warmup, fewer hot spots, and less corrosion may offset the higher initial cost Will
Formerly Aero S5 #80 Currently 911 (992) Targa in python green
Posts: 1,415 |
There's a case for waterless coolant, pro & con article hereOn a car you plan to keep, faster warmup, fewer hot spots, and less corrosion may offset the higher initial cost Will Don't get me started on waterless coolant.....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,915 Likes: 95
Posts: 1,915 Likes: 95 |
