Morgan Aero 8
4 members (IcePack, Zach, BobtheTrain, Rog G), 224 guests, and 39 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Peter J #737903 03/04/22 10:38 AM
PJC Offline
This is the stuff that Brand Hatch Morgan use and said that should be used in these BMW V8s. A quick "Google" and I found it easy to get online.
Cheers, Paul
Peter J #737931 03/04/22 06:12 PM
Before someone points out colour is not always proof of what specific version of antifreeze it is...BUT that blue stuff above that only has a 2 year life is pretty basic 'trade' quality, you need to see the small print on the can to check it's BS spec
CooperMan #737933 03/04/22 06:15 PM
TBM Offline
Looks like it's the basic IAT
Quote
Autochem ABL001 Blue 2 Year Antifreeze
This concentrated 2 Year Antifreeze is a methanol free formulation suitable for all engine types, providing exceptional all year-round protection and performance, in all driving conditions. Contains anti-corrosion additives, allowing it to inhibit rust within the system for a maximum of 2 years. Suitable for use in many Classic/Vintage vehicles.
SPECIFICATIONS
Manufactured to meet BS6580 (2010).
Peter J #737936 03/04/22 06:49 PM
VERY basic stuff, not much better than the Blucol I used to flog in the '70's
Peter J #738003 04/04/22 05:01 PM
Peter J Offline OP
Formerly known as Aldermog
I see there are newish formulations compatible with both IAT and OAT based antifreeze.
I suspect that MMC uses the cheap stuff... next service I'll get the system drained and refilled with OAT Longlife antifreeze/coolant.
Peter J #738006 04/04/22 06:13 PM
I'm pretty sure this is what's in my car Mannol long life
Seems to tick all the boxes...
2016 Aero 8 S5
Peter J #738055 05/04/22 09:18 AM
Used the same stuff in my Roadster after fitting SiFab rad. A bit of research revealed it was up to the job. Found source on eBay.
Although described as concentrated to -40°C protection it's designed to be used neat. Factory coolant drained out tested to same freezing point.
Peter J #738069 05/04/22 11:47 AM
There's a case for waterless coolant, pro & con article here
On a car you plan to keep, faster warmup, fewer hot spots, and less corrosion may offset the higher initial cost
Will
Formerly Aero S5 #80
Will
Don't get me started on waterless coolant..... swear
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Peter J #738095 05/04/22 03:15 PM
Here’s a classic thread from 2016….
http://www.talkmorgan.com/ubbthreads.php/topics/335929/1
