7 members (Goldman, TBM, TeddyAds, SailingTom2, Guten, Image, MartinB60),
88
Topics49,899
Posts838,021
Posts: 61 Likes: 3
Posts: 61 Likes: 3 |
Preparing our newly acquired 1973 +8 RHD for MOT, we are replacing the old rubber brake hoses with new braided ones. Looks like the brake pipes haven't been attended to during all the years and I would like to replace all of them with preferably, copper pipes. So far I haven't been able to find out where to buy them. Our local Morgan pusher claims that such a kit doesn't exist and will have to be made up from case to case. Sounds wierd to me... Anybody here who knows if and where to buy such as a kit? Our +8 is factory fitted a brake booster. Cheers /Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
If Melvyn Rutter doesn't do pre-made sets, then I honestly doubt that anyone else would. Fortunately however he does sell the braided lines, the pipe, and the fittings. https://mogparts.net/shop/brake-clutch/brake-pipes-hoses
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
As you can see from this thread - Installing Brake Lines - PaulyG bought a ready made set from Morgan Spares (USA) and only 2 (out of 7) of them fitted his car. I think getting them made up will be the easiest option (altough may be more expensive). Or you could DIY.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Have you tried Automec?
They used to list Morgan brake pipe kits
Mind you, I make my own up!!
Arwyn
Posts: 61 Likes: 3
Thanks guys for your advise. Arwyn, I will try Automec, used them for an MGA we used to run years ago. If it fails I may have to make them up myself... I do have the bending tool (from the restoratuion of our AH 3000), but would then also get the tool to flare the ends. Another thing is that while we used copper pipes for our AH 3000, I'm about to be convinced that cunifer (blend of copper and nickel) is even better and more corrossion resistant and even easier to work with. As Tim pointed out Melvin seems to have both to be bought by the length. What's your opinion?
Posts: 172 |
I have been very satisfied with Automec copper nickel sets.
Automec list the following sets for Morgans:- GB5081 Brake Pipe Set Morgan Plus 8 1973-76 4 speed GB5084 Brake Pipe Set Morgan 4/4 1967 type GB4980 Brake Pipe Set Morgan 4/4 1972 GB5090 Brake Pipe Set Morgan 4/4 1974 type 4 seater GB5647 Brake Pipe Set Morgan 4/4 2 Seater 1981-1988 GB5080 Brake Pipe Set Morgan 4/4 4 seater 1981 type GB5111 Brake Pipe Set Morgan 4/4 Ser 4 GB4979 Brake Pipe Set Morgan Plus 4 1950-59 Girling GL5083 Brake Pipe Set Morgan Plus 4 2138cc 1961 type GB5083 Brake Pipe Set Morgan Plus 4 2138cc 1963 type GL4979 Brake Pipe Set Morgan Plus 4 50>59 Girling GB5644 Brake Pipe Set Morgan Plus 8 1977-78 with servo GB5082 Brake Pipe Set Morgan Plus 8 1977-79 5 speed GB5648 Brake Pipe Set Morgan Plus 8 1980/81 type
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 327 |
Much more satisfying to get the brass fittings and cupro nickel tubing from automec and strangle the the pipework Yourself. Just did my Caterham 7 last year
Posts: 61 Likes: 3
Hi Jack, this is awesome! GB5081 is exactly what we need it seems and I will get hold of Automec on Monday. Question is now if we should go for copper or cupro nickel. Cupro nickel is more expensive and apparently mandatory for Germany, so question is if that applies for the entire EU (I'm in Denmark). Automec may know. Cheers /Finn
Posts: 172 |
Finn, My experience is that copper pipes swell inside the fitting and then the pipe twists when you unscrew the fittings. I have reused cupro nickel pipes many times.
Posts: 61 Likes: 3
Automec charges GBP 167 for a complete set of either copper or cupro; the price is the same and the vendor pointed out that many countries prohibits copper. Hence cupro it is! We already have a bending tool and I'm happy that we don't have to buy tools and mess with flaring etc. After all brakes is a delicate matter!
Thanks to all for your inputs and advice.
Finn
