2 members (Zach, DCH), 222 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 5 of 7 1 2 3 4 5 6 7
Bonesie #738338 08/04/22 04:25 PM
Richard, I was told an analogue output of speed or if not available then they fit the GPS sensor. The importer / distributor in Manningtree suggested he use his best dealer. When I mentioned the guy in Derby Gary & I were with this week that is who it is. I'll keep you posted.
John V6 #738344 08/04/22 04:47 PM
Originally Posted by John V6
I am persuing the cruise control. It seems it can be done. Ideally I need to find an analogue speed signal off the canbus. Does anyone know where that would be?
The alternative is a GPS sensor.
I found a specialist who seemed to know what we need, problem is they can't get the IC chips for the unit we need for CANbus, but I'll try and dig out the contact info
Bonesie #738355 08/04/22 07:04 PM
I'm inclining to the simpler stand alone GPS that doesn't have to mess with MMC's ECU/ BCU bits. Will update you next week if a KISS solution will work
Bonesie #738389 09/04/22 07:34 AM
Connecting to CanBus is not that onerous John. You tap into back of OBD2 plug. You need +12V, Ground, Can High & Can Low, connected to decoder to give speed pulse output.
I would be concerned using GPS to control speed as you would loose signal when satellite coverage is lost, in cities, tunnels etc.
Bonesie #738391 09/04/22 07:51 AM
I know Richard. I'll let you know what the importer says & then talk to Brian in Derby.
Bonesie #738458 09/04/22 05:06 PM
Here you go chaps,
The cruise control mfr that the OP used recommended Sailes marketing
Had a lengthy chat with Sailes and although not familiar with Mogs he was confident we would get a result as it works with most usual modern Fords
You need the CANbus module
https://sailesmarketing.com/shop/can-bus-interfaces/cb-1-can-bus-interface/
This can be connected without breaking into the harness
https://sailesmarketing.com/shop/can-bus-interfaces/canclick-contactless-can-reader/
Or via OBD
https://sailesmarketing.com/shop/accessories/obd-connector/
Bonesie #738463 09/04/22 05:25 PM
Thanks Jon that makes sense to me.
Bonesie #738819 13/04/22 02:42 PM
I am booked in to get it fitted 26/4. Cost £595 being done by the importer's best agent who is based in Derby. Will update you all later.
John V6 #738846 13/04/22 06:55 PM
Waiting with interest on this one
Bonesie #740220 26/04/22 08:08 PM
Today I got it fitted. I'll write a full write up later but it works well. Jon you will be able to see it on Sunday
