4 members (Montegue, jbk, TalkMorgan, KennyW), 307 guests, and 83 robots.
Sagging Hood
Topics49,858
Posts837,463
#738564 10/04/22 07:15 PM
PaulyG Offline OP
I removed the sidelights on the front wings to replace the rubber pieces. Underneath was a letter "A" stamped on the wing. I was thinking, and hoping, that meant aluminum. But they are steel.
Or maybe it's a "V". Or an arrow pointing back which would seem silly.
Anyone know what it means?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #738573 10/04/22 08:37 PM
It may be none of the above. A bit like the Father Ted episode in which an image of Bishop Brennan miraculously appears in the skirting board of the Craggy Island parochial house https://youtu.be/x4hG6sOw34w
PaulyG #738591 11/04/22 07:29 AM
First thought was an imprint into soft paint from the sidelight base but maybe you checked that [Linked Image]
PaulyG #738592 11/04/22 07:36 AM
It is a mathematical symbol meaning ‘greater than’.
In this case it refers to the first rule of Morgan ownership which states that the cost of this repair will be much greater than you anticipated.
S3 Roadster Brooklands LE 3/50.
PaulyG #738599 11/04/22 07:52 AM
The letter “V” for victory, for having been able to remove the sidelight, without having to use major surgery.
PaulyG #738609 11/04/22 10:31 AM
Black Rat
Black Rat
fit facing forward ?
Keith
2013 narrow bodied + 4 Ruby.
PaulyG #738614 11/04/22 10:42 AM
I think as said it point to where the front of the wing is just in case you don't know.
Or maybe the metal basher was on piece work and that is his masons mark
John V6 #738618 11/04/22 11:11 AM
Isn't it pointing to the back?
2011 Morgan 4/4
1932 Austin 7 Chummy
PaulyG #738619 11/04/22 11:21 AM
I tend to go with Richard's thinking...an imprint in the paint. Only by sanding it down to bare metal will you know for sure it's a stamp.
PaulyG #738621 11/04/22 12:30 PM
PaulyG Offline OP
I never thought to check the underside of the sidelight base. I will check it when I get home.
But I hope it's not that. I like the other answers much more! smile
73 4/4 "Henry A"
60 MGA
