4 members (Strathaven, Graham, G4FUJ, RichardV6, hillclimber), 206 guests, and 77 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,456
PaulyG #738747 12/04/22 09:25 PM
PaulyG Offline OP
Some clever folks here. Yes, it's the letter A on the underside of the side light rubber piece.
Judging by the paint underneath it seems they put the side lights on, then buff the paint out.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #738772 13/04/22 07:56 AM
……but what is the meaning of the letter ‘A’?
S3 Roadster Brooklands LE 3/50.
Black Rat
Black Rat
Point this piece up hide
Keith
2013 narrow bodied + 4 Ruby.
PaulyG #738780 13/04/22 08:41 AM
Probably the mould they used assuming there are several moulds or the size if they have similar items
PaulyG #738782 13/04/22 08:50 AM
Morgan bolt things up before the paint hardens fully. I think the uneven paint surface is just a reflection of the compressed rubber.
My Plus 4 has an outline of the cowl badge in the paint, so I can't fit the older style badge without serious work.
DaveW #738784 13/04/22 08:59 AM
TBM Offline
Not just Morgan - I've just replaced the bonnet catch fittings for some swanky stainless flat head bolts. The previous bolts had obviously been fitted when the paint was fresh as there's very obvious dents left by the previous ibadly aligned washers (the painter also seemed to like to use copious amounts of skim filler).
Not bothered enough to change it back but will have to remedy at some point.
