Topics49,858
Posts837,463
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
I removed the sidelights on the front wings to replace the rubber pieces. Underneath was a letter "A" stamped on the wing. I was thinking, and hoping, that meant aluminum. But they are steel. Or maybe it's a "V". Or an arrow pointing back which would seem silly. Anyone know what it means? ![[Linked Image]](https://tm-img.com/images/2022/04/10/PXL_20220410_164646665.jpg)
Posts: 1,983 Likes: 103
Posts: 1,983 Likes: 103 |
It may be none of the above. A bit like the Father Ted episode in which an image of Bishop Brennan miraculously appears in the skirting board of the Craggy Island parochial house https://youtu.be/x4hG6sOw34w
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
First thought was an imprint into soft paint from the sidelight base but maybe you checked that ![[Linked Image]](https://i.imgur.com/gBEtBcZ.gif)
Posts: 63 |
It is a mathematical symbol meaning ‘greater than’.
In this case it refers to the first rule of Morgan ownership which states that the cost of this repair will be much greater than you anticipated.
S3 Roadster Brooklands LE 3/50.
Posts: 58 |
The letter “V” for victory, for having been able to remove the sidelight, without having to use major surgery.
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
I think as said it point to where the front of the wing is just in case you don't know. Or maybe the metal basher was on piece work and that is his masons mark
Posts: 3,696 Likes: 131
Posts: 3,696 Likes: 131 |
I think as said it point to where the front of the wing is just in case you don't know. Isn't it pointing to the back?
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I tend to go with Richard's thinking...an imprint in the paint. Only by sanding it down to bare metal will you know for sure it's a stamp.
I never thought to check the underside of the sidelight base. I will check it when I get home. But I hope it's not that. I like the other answers much more!
