7 members (JMcL, John Winn, DPEvans, Davetherave, TBM, BobtheTrain, Craig Jezz),
336
84
Topics49,859
Posts837,478
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
Some clever folks here. Yes, it's the letter A on the underside of the side light rubber piece. Judging by the paint underneath it seems they put the side lights on, then buff the paint out. ![[Linked Image]](https://tm-img.com/images/2022/04/12/PXL_20220412_212034613.jpg)
Posts: 63 |
……but what is the meaning of the letter ‘A’?
S3 Roadster Brooklands LE 3/50.
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
……but what is the meaning of the letter ‘A’? Point this piece up
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Probably the mould they used assuming there are several moulds or the size if they have similar items
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Morgan bolt things up before the paint hardens fully. I think the uneven paint surface is just a reflection of the compressed rubber.
My Plus 4 has an outline of the cowl badge in the paint, so I can't fit the older style badge without serious work.
Posts: 6,669 Likes: 433
Posts: 6,669 Likes: 433 |
My Plus 4 has an outline of the cowl badge in the paint, so I can't fit the older style badge without serious work. Not just Morgan - I've just replaced the bonnet catch fittings for some swanky stainless flat head bolts. The previous bolts had obviously been fitted when the paint was fresh as there's very obvious dents left by the previous ibadly aligned washers (the painter also seemed to like to use copious amounts of skim filler). Not bothered enough to change it back but will have to remedy at some point. ![[Linked Image]](https://tm-img.com/images/2022/04/13/IMG_20220409_120845-COLLAGE.md.jpg)
