9 members (RedThree, DavidR, Image, Strathaven, TalkMorgan, linklaw, RobCol, MATTMOG, sid),
107
36
Topics49,906
Posts838,105
Posts: 502 |
As shown here in Mogparts listing. ![[Linked Image]](https://mogparts.net/thumbnails/userfiles/files/CRM094%282877%29_500x500cc.JPG) Presumably the part that protrudes through the skin has a female square section to match and engage with the door lock square shaft. A quick phone call would confirm this. Yes Richard, I can confirm this is correct. I received my order from BHM this morning, but annoyingly they have only sent one handle, not as a pair as advertised. Waiting for an email to confirm the other is to follow. I bought them specifically from them so that they will both have the same key. Grrrr
2004 Series 1 Roadster
Posts: 8,700 Likes: 416
Posts: 8,700 Likes: 416 |
Spare matching lock barrels available from Rimmer Bros. if needed. ![[Linked Image]](https://rimmerbros.com/ItemImages/Large/409931-Zoom.jpg)
Posts: 502 |
![[Linked Image]](https://www.tm-img.com/images/2022/04/20/DSC_0508.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/04/20/DSC_0507.jpg) First one done, just waiting for the other one to be delivered. Must admit it was more tricky than I had envisaged due to having to drill out some holes for the base plate lugs, but the advice on the plastercine to leave a witness mark as a drilling guide was great!!!
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Glad it went well. To show how items can slightly differ......my handles do not have lugs on the roses, completely flat. Presumably they couldn't be ground off?
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 502 |
Glad it went well. To show how items can slightly differ......my handles do not have lugs on the roses, completely flat. Presumably they couldn't be ground off? I could easily dremmel them off, but it gives it a little extra stability from preventing the rose from turning, above what the screws give. Second one should be easier to fit as I know what made things a little trickier for me. My "stepped" drill bit was really useful but needed it to be a bit wider as I needed a hole bigger than 20mm so had to grind it out with my dremmel, which I discovered is far better at drilling than my cordless drill when drilling the holes for the metal for the screws.
