1 members (davewhite), 277 guests, and 67 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
#739646 21/04/22 08:17 AM
Felix42 Offline OP
My cheap Halfords trolley jack has finally succumbed to the trolley jack equivalent of arthritis. Can anyone one suggest a not too expensive replacement? My own arthritis stops me getting under my car very often so it would not get a lot of use, but it is essential to have one. Many thanks for your comments.
Felix42 #739649 21/04/22 08:32 AM
I have human arthritis and recommend spending a bit more and getting an aluminium jack. So much easier to heave around the place.
Felix42 #739653 21/04/22 08:48 AM
Felix42 Offline OP
Good suggestion, Griffo.
Felix42 #739663 21/04/22 09:38 AM
Never had much luck with aluminium jacks, they just seem too flimsy for heavy duty use.
Whatever you get, make sure you can get a service kit for it.
I've had a 3 ton Sealey Yankee for longer than I care to remember, I fitted a new seal kit about 6 years ago when it started to leak. Seal kit was 6 quid and tge job took about 30 mins!
Arwyn
Felix42 #739666 21/04/22 09:50 AM
if you have (or have access to!) a Costco card , they often have some good quality, low entry ally jacks on offer.
Might be worth a look....
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Felix42 #739667 21/04/22 09:58 AM
+1 on the thinking that a low level jack can get under where normal jacks may not. I bought one from machine mart, had it delivered, has been doing the job for a few years now but not used much these days.. oldgit
James B W #739673 21/04/22 10:27 AM
Felix42 Offline OP
Thanks for all your comments. I need to measure my Roadster for clearance under the axle-thing that the jack goes under. She's quite low to the ground at the front.
James B W #739674 21/04/22 10:29 AM
Felix42 Offline OP
The nearest Costco outlet is 80 miles away in Bristol!
Felix42 #739687 21/04/22 11:54 AM
Axle clearance isn't usually a problem on mine, but the number plate is bumper slung, so I like the look of this, for when I eventually get a flat, level workspace.
https://www.toolden.co.uk/p/sealey-...5vgRtc1F0U21nAcu68TQcSpHwWoaAhNWEALw_wcB
06 Saab 93
Felix42 #739690 21/04/22 12:05 PM
Ooops!
- perfect excuse for a run out in the Mog...... innocent
James
Monkey Z125
