1 members (Saxonian),
270
70
Topics49,849
Posts837,424
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
My cheap Halfords trolley jack has finally succumbed to the trolley jack equivalent of arthritis. Can anyone one suggest a not too expensive replacement? My own arthritis stops me getting under my car very often so it would not get a lot of use, but it is essential to have one. Many thanks for your comments.
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
I have human arthritis and recommend spending a bit more and getting an aluminium jack. So much easier to heave around the place.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Never had much luck with aluminium jacks, they just seem too flimsy for heavy duty use.
Whatever you get, make sure you can get a service kit for it.
I've had a 3 ton Sealey Yankee for longer than I care to remember, I fitted a new seal kit about 6 years ago when it started to leak. Seal kit was 6 quid and tge job took about 30 mins!
Arwyn
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
if you have (or have access to!) a Costco card , they often have some good quality, low entry ally jacks on offer.
Might be worth a look....
James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 5,439 Likes: 467
Posts: 5,439 Likes: 467 |
+1 on the thinking that a low level jack can get under where normal jacks may not. I bought one from machine mart, had it delivered, has been doing the job for a few years now but not used much these days..
Thanks for all your comments. I need to measure my Roadster for clearance under the axle-thing that the jack goes under. She's quite low to the ground at the front.
The nearest Costco outlet is 80 miles away in Bristol!
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Axle clearance isn't usually a problem on mine, but the number plate is bumper slung, so I like the look of this, for when I eventually get a flat, level workspace. https://www.toolden.co.uk/p/sealey-...5vgRtc1F0U21nAcu68TQcSpHwWoaAhNWEALw_wcB
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
The nearest Costco outlet is 80 miles away in Bristol! Ooops! - perfect excuse for a run out in the Mog......  James
