7 members (Jack Noir, Oliemog, SEG, SailingTom2, James B W, High Hamster, Scrambledsignals),
413
40
Topics49,915
Posts838,212
Posts: 37,490 Likes: 994
Posts: 37,490 Likes: 994 |
Last time I had some 4.0 to use up so that went in.
From a sealed/unopened container hopefully? It is Dave we are talking about here - I will guarantee they will be sealed and in date order with a strict rotation being adhered to at all times
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Richard knows my habits well
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
The only time I had a completely new and dry braking system, when I rebuilt my BV8, I thought long and hard about using silicon fluid.
In the end, there were just enough stories of sticking cylinders, and spongy feel to put me off.
Maybe on a dry fill it would have been OK. but it was never adopted by manufacturers so far as I know.
I've been using dot 5.1 in my Roadster, until the last replacement, which has similar performance properties to silicon, but is conventional brake fluid.
Well, you can all consider me as a guinea pig, having had silicone fluid for three years. I have not noticed any spongy feel, no significant difference compared to pre-silicone period. I might have if I were tracking my car, who knows. But being the cruiser I am, I experience just the same braking feel. As for sticking cylinders, one piston in each cylinder did stick. But as the cylinders most likely had been there since 2004, I believe the sticking was because of old age and visible rust, not the silicone fluid. Again I emphasize the importance of extremely thorough flushing of the system before filling up with silicone. No issues so far, but if anything turns up, I will report immediately
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
From a sealed/unopened container hopefully? It is Dave we are talking about here - I will guarantee they will be sealed and in date order with a strict rotation being adhered to at all times  Yes, i would be surprised to hear otherwise. The remark was a bit “tongue in the cheek“ but aimed more at the uninitiated, who might get the wrong idea and use up their slops!
Posts: 81 Likes: 1
Posts: 81 Likes: 1 |
Which brand are considered as the best quality replacements?
Kevin Davies
I fitted a pair of these 7 years ago and they are still working fine on my Plus 8. I think they came in a Delphi/Lockheed box or Caparo by then  . It was an easy job unlike replacing the shoes. These are also recommended Gammon If you have an older model car your brakes will be Girling and these will not fit.
