3 members (Morganmike, DJC, Rastus), 143 guests, and 32 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#740415 29/04/22 12:29 AM
Dutch Offline OP
Can someone tell me what these numbers mean on the plate ?
C No. R8905 I assume this is the serial number. Where can I get some info on the car ?
11R-0103
12R-0103
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #740419 29/04/22 05:38 AM
Yes, R8905 is the chassis number.
The Morganville Registry run by Tony McLaughlin has over 5000 entries and I see your car is in there as a brown 1981 +8. The contact details for the past owner are there (I'll make no comment on the data protection issues with that!)
You can order a "Chassis Record" from the Morgan Motor Company at https://www.morgan-motor.com/chassis-records/. However, at £80 for a single A4 sheet, this is a tad expensive and doesn't give you much more than the original spec and delivery date.
There is a useful article on GoMog https://www.gomog.com/allmorgan/ChassisNumbers.html. If you haven't already found it, there may well be an etching on the bonnet hinge.
I don't know what the other two numbers mean, my chassis plate has the same ones.
2011 Morgan 4/4
1932 Austin 7 Chummy
Dutch #740420 29/04/22 05:40 AM
Try the Morganville register. The r number is the chassis number
https://morganville.org/
Dutch #740421 29/04/22 05:46 AM
Beat you John!
2011 Morgan 4/4
Dutch #740423 29/04/22 07:13 AM
No worries
Dutch #740514 30/04/22 01:39 AM
Dutch Offline OP
Got this information from a Brit friend of mine.
The English plate is CNP 707W
The W on the license plate does indeed indicate it was registered in 1980, The second and third characters (NP) suggest it was registered in Worcester.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #740519 30/04/22 07:04 AM
You didn't say it had a Britsh registration! That's curious, is it a right-hand drive?
The "W" means it was registered between 1 August 1980 and 31 July 1981. It is on the DVLA database www.gov.uk/get-vehicle-information-from-dvla
Showing as a 1981 car, which matches with the Morganville registry (the chassis numbers before and after yours are also 1981).
It looks like it spent a couple of years on British roads before being exported to the US. "NP" is indeed Worcestershire so maybe it was a factory demonstrator?
2011 Morgan 4/4
Dutch #740653 01/05/22 06:06 PM
Dutch Offline OP
Yes it is right hand drive. I assume that's why it wasn't converted to propane.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #740775 03/05/22 01:11 AM
Dutch Offline OP
Do to it's age I'll be able to get a Historic plate here in Ohio. Only $ 10 and it's good until 2050.
I've heard that I don't have to mount the plate as I've got the British plates on the car. You just have to keep the historic plate in the car in case you get stopped. I'm going to check that out to make sure that's the case.
Thanks again for all your good information.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #741747 12/05/22 08:45 PM
Dutch Offline OP
Well I could only use a 1980 Ohio plate not the UK plates. But I'll keep the UK plates on the car and mount the historic plate too on the rear
Our first Cars and Coffee is this weekend. Can't wait to show off the Morgan. Just wished the 3 Wheeler was out of the shop.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
