Morgan Aero 8
2 members (Bunny, Jon G4LJW), 247 guests, and 80 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 3 of 3 1 2 3
Neilda #741155 06/05/22 05:56 PM
Originally Posted by Neilda
First drive out today and first visit to the petrol pump. It's fixed! It fills just like any other car - nozzle right in, squeeze as hard as you like. Fantastic - I'm delighted as it was the only real negative I had about the car. I dreaded filling it. Thank you MMC. smile
Neil, do you know what MMC did as the cure ?
CooperMan #741219 07/05/22 09:52 AM
Neilda Offline OP
Yes - they listed:
Machine Shop Supply Fuel Adapter.
Tank Rubber Gasket
Petrol Hose 1/2 Inch Bore
Petrol Cap Side Vent 12mm
I assume bigger vents/bores and an especially made up 'supply fuel adapter' - but I don't know what this is.
It was worth having done as filling the car was beyond tedious. It was painfully slow (gingerly pressing the trigger etc) but also not really knowing if the car was actually full.
Worth adding that previously I would end up with my feet covered in petrol as it would also suddenly woosh out of the filler cap. This has stopped too.
+8 4.8
Neilda #741264 07/05/22 06:44 PM
Yes - they listed:
Tank Rubber Gasket
Many thanks
Does yours have this mis filling plate removed now ?
I ask because I have a pal with a trad that has problems of fuel burp & can never get a full tank, & I suspect the unleaded only breather plate below could be removed
CooperMan #741306 08/05/22 08:49 AM
Neilda Offline OP
The inside of the cap looks as it did before - so I don't think that plate has been removed.
+8 4.8
Neilda #741313 08/05/22 09:04 AM
I cant easily fully fill the tank. So this is interesting.
Neilda #741318 08/05/22 09:43 AM
I had this problem with my series 1 roadster when new. I found that the plate with all the holes in pictured above rotates very freely. Only when the hinge is at 12 o'clock will the car fill properly.
That's my memory of it, I just rotated the plate using a pencil and the problem went away.
I should call it the flap, not the plate.
Nick
Neilda #741324 08/05/22 11:26 AM
Just tried the 12 oclock apporach & that seems to help
John V6 #741385 09/05/22 07:13 AM
Neilda Offline OP
I have to say that it's a bit of a game changer being able to fuel easily - but also recognise that it's major faff to take it to the factory. I am glad I have had mine done.
+8 4.8
Neilda #741399 09/05/22 08:39 AM
Smile, it confuses them
That was one of the things that used to drive me a little bit (more) nuts - it was a big change as you say.
Page 3 of 3 1 2 3
