Topics49,838
Posts837,293
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
As usual this forum is the best. My car should be here tomorrow so I'll check it out.
Thanks all
Dutch
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 218 Likes: 5
Posts: 218 Likes: 5 |
Does someone know where I can get the hardware to put on a bonnet strap ?
1980 + 8 I hope this picture helps ![[Linked Image]](https://tm-img.com/images/2022/05/06/F57E5FB3-EA1A-4CF7-9A7C-8C788FFFCAC7.jpg) Mine also has a couple of small studs, one on the top of each half of the bonnet, to hold the strap in place between the two banks of louvres and to limit any movement of the belt that might damage the paint finish. A couple of holes in the belt needed to locate the belt on the studs
Ken Current 2003 +8 35th Anniv. Model 2014 Porsche Boxster GTS Previous 1996 Jaguar XJS Celebration
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Contributed to this thread a couple of years ago, but recent mods I'm most pleased with are:
1) SiFab aluminium radiator to replace leaking OE 2) Adding switchback LED lighting in front indicator position 3) Shortening number plate mount box to match grill.
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
1980 + 8 I hope this picture helps ![[Linked Image]](https://tm-img.com/images/2022/05/06/F57E5FB3-EA1A-4CF7-9A7C-8C788FFFCAC7.jpg) Mine also has a couple of small studs, one on the top of each half of the bonnet, to hold the strap in place between the two banks of louvres and to limit any movement of the belt that might damage the paint finish. A couple of holes in the belt needed to locate the belt on the studs I applied PPF to stop any paint damage ![[Linked Image]](https://tm-img.com/images/2021/01/31/AEB278B1-F60A-4D00-A3DB-7EC8D17153AB.jpg) ![[Linked Image]](https://tm-img.com/images/2021/01/31/06503C0E-97E9-43E8-A161-40FF4127C45F.jpg)
Craig Jezz
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Ditto I have PPF but no paint on mine. More scratch protection. ![[Linked Image]](https://www.tm-img.com/images/2022/01/27/20220126_120324.jpg)
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
How do you deal with where the strap crosses the louvres ? ...... do you cut the protective tape with a razor blade to just cover the 'sticky up bits' while leaving the openi gs clear?
This is a job I will be doing shortly
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
K Aha! Another advantage of having ‘reduced’ louvres, as on my 4/4! The strap is just forward of the louvres,  However, I did covet the 70th Anniversary 4/4s which had both the 1.8 Duratec engine and a gap in the louvres, where the bonnet strap sat. On my 4/4 the mods I’ve added are a Mulfab Al radiator, (many years ago), a wire grille, to protect it, round door mirrors and a wood rim steering wheel. Bud 4/4 - Stanley
Bud 4/4 "Stanley"
On my car the ppf stops just before the louvres, no big issue with polished alloy. My last Roadster had a belt but no PPF . I took that off as I was worried fir the paint. The edges of the loveres were piantless.
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
I have a few simple mods on my Roadster that I could not live without -
1. Door checks - otherwise before long your shins will be black and blue. 2. Sports exhaust - for that charismatic deep rumble. Motoring should be a sensory experience and the ears are as important as the eyes. i have the Librands sports exhaust which i think sounds better than the Morgan version. 3. Morgan Park chrome steering column and stalks - a bit pricey but so much nicer than the standard plastic efforts from Morgan. 4. Round side mirrors - perfect finishing touch for the exterior.
I have never regretted any of these extras, even though they add up to a fair sum.
David 2020 Roadster 3.7 Dove Grey.
K How do you deal with where the strap crosses the louvres ? ...... do you cut the protective tape with a razor blade to just cover the 'sticky up bits' while leaving the openi gs clear?
K Yes I cut small pieces of PPF for the louvres
Craig Jezz
