6 members (thelastgizmo, Paulxj, GrumpyPa, Barkbark, Mike D, mph), 238 guests, and 36 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
#741184 06/05/22 10:00 PM
I have just received notice of maintenance to the TM Image Library service. Basically this means that images will not be available for a 3 hour period at the date and time below.
Quote
Dear Peter
We are reaching out to inform you of an upcoming software maintenance that needs to be performed on the server where your account with primary domain name tm-img.com resides.
The maintenance will be performed due to the old MariaDB version which needs to be upgraded before it reaches EoL (End of Life), due to this we are opening a 3 hour window in which we should be able to upgrade the MariaDB server and engine, during this 3 hour window there will be downtime as the MySQL service will be stopped briefly for this. :
Maintenance Start: 12th of May, 2022, at 17:00 PM (UTC)
Maintenance End: 12th of May, 2022, at 20:00 PM (UTC)
Additionally, we would like to note that this event will not affect the data of your account in any form of way as it will be upgrading only the underlining software which fully supports the currently used data, everything on the old MariaDB engine will work in the same way on the new one, the reason behind the upgrade is security, stability and most of all performance.
The new version of the MariaDB server will be the recommended stable one 10.3.
If you have any questions related to this process, our teams are 24/7 available at your immediate disposal.
Warmest regards,
Rachel Wilson
The TMDHosting Team
TMDHosting, Inc. 618 E South Str, Orlando FL 32801.
TM Image Library was set up independently for the use of Talk Morgan forum members
Thanks for hosting this Peter
thumbs smile
Great service as ever thumbs
John V6 #741274 07/05/22 08:29 PM
Thank you thumbs
I would like to add may name to the list of those thanking you for your efforts re: the Image Library Peter. I really enjoy viewing other folks pics.. thumbs
OZ 4/4 #741470 09/05/22 04:37 PM
Thank you thumbs
thumbs
Bert & B1800
