1 members (JMcL), 195 guests, and 41 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
#742256 18/05/22 05:40 PM
Leroy Offline OP
So, today I leant across the back of the car to adjust the hood cover and my bare arm touched the luggage rack. I could feel a very slight electric shock as I touched it. Its hooked up to a battery maintainer but can anyone offer a possible cause?
2004 Series 1 Roadster
Quite possibly static electricity build up on your body discharging to earth?Often created from wearing synthetic fibres.
However, I would also inspect the mains side of the battery maintainer to ensure the insulation is perfectly intact.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Rog Offline
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away….
Roger
Leroy Offline OP
I unplugged the maintainer, moved the extention lead from where it was and plug it back in, and the shock has gone. Should have touched the rack first to confirm if it could have been static but too late now. Either way it's stopped for now. I'll just keep an eye in it. Thanks for your input.
I've noticed the same too, but as the garage is all on modern circuit trips and a fast RCD I'm not too worried
It's not as powerful as licking a PP3 battery that we did as kids eek
I don't know why, but I still do that; maybe its due to inflation🤷‍♂️
06 Saab 93
Hi Rog don't throw it away just use a relay. But don't forget to earth it correctly.
rofl
Rob..
Why is there only one monopolies commission??
Rob B.
I wonder if some of these findings are due to dodgy/home spun garage power installations. There is a maximum distance apparently above which the local house mains ground is not acceptable. The armoured cable sheathing ground feeding an outbuilding is broken at that end and a local ground rod used instead for the benefit of local RCD and safety in general.
Rog Offline
rofl
Rob..
If Jon's does it too then it might just be a 'feature'’. l will wear my wellies, it’ll be fine farmer
Roger
Quite possible - when I had my workshop overhauled last year the electrician insisted it needed it’s own ground rod separate from the house - a 1m copper rod sunk into the earth.
Mike H
Bourgogne Franche Comté
