2 members (ChrisM, Tresco),
272
34
Topics49,904
Posts838,088
Posts: 502 |
So, today I leant across the back of the car to adjust the hood cover and my bare arm touched the luggage rack. I could feel a very slight electric shock as I touched it. Its hooked up to a battery maintainer but can anyone offer a possible cause?
2004 Series 1 Roadster
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Quite possibly static electricity build up on your body discharging to earth?Often created from wearing synthetic fibres. However, I would also inspect the mains side of the battery maintainer to ensure the insulation is perfectly intact.
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away….
Roger 2011 Plus 4
Posts: 502 |
I unplugged the maintainer, moved the extention lead from where it was and plug it back in, and the shock has gone. Should have touched the rack first to confirm if it could have been static but too late now. Either way it's stopped for now. I'll just keep an eye in it. Thanks for your input.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away…. I've noticed the same too, but as the garage is all on modern circuit trips and a fast RCD I'm not too worried It's not as powerful as licking a PP3 battery that we did as kids
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away…. I've noticed the same too, but as the garage is all on modern circuit trips and a fast RCD I'm not too worried It's not as powerful as licking a PP3 battery that we did as kids  I don't know why, but I still do that; maybe its due to inflation🤷♂️
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 194 Likes: 5
Posts: 194 Likes: 5 |
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away…. Hi Rog don't throw it away just use a relay. But don't forget to earth it correctly.  Rob..
Why is there only one monopolies commission??
Rob B.
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
I wonder if some of these findings are due to dodgy/home spun garage power installations. There is a maximum distance apparently above which the local house mains ground is not acceptable. The armoured cable sheathing ground feeding an outbuilding is broken at that end and a local ground rod used instead for the benefit of local RCD and safety in general.
I have a CETK. The isolation is dreadful. I get a buzz if I touch the car too. I must get around to throwing it away…. Hi Rog don't throw it away just use a relay. But don't forget to earth it correctly.  Rob.. If Jon's does it too then it might just be a 'feature'’. l will wear my wellies, it’ll be fine
Roger 2011 Plus 4
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
I wonder if some of these findings are due to dodgy/home spun garage power installations. There is a maximum distance apparently above which the local house mains ground is not acceptable. The armoured cable sheathing ground feeding an outbuilding is broken at that end and a local ground rod used instead for the benefit of local RCD and safety in general. Quite possible - when I had my workshop overhauled last year the electrician insisted it needed it’s own ground rod separate from the house - a 1m copper rod sunk into the earth.
Mike H Bourgogne Franche Comté
