9 members (piquet, vincentvg, IcePack, DJC, Craig Jezz, Cat302, DaveK, ChrisConvertible, gmcn),
337
Topics49,838
Posts837,295
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
This link takes you to FUEL PUMP REPLACEMENT GUIDE. It's a straight-forward DIY job but remember that there may be slight differences in the hardware used depending on what MMC had available at the time of manufacture.
Andy
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Hi guys, thanks for all your input, done nothing as yet other than the purchase of a Walpro pump and also a US Pro fuel pump pressure testing kit off eBay, an absolute bargain at less than £25. The Factory are adamant that it is the Crank position sensor but have none in stock. My idea was to drive the car until it stopped then change the sensor at the side of the road as opposed to having to change the fuel pump. The sensor looks suspiciously like a Harley one, Anyone know? Thanks in advance.......
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
"The sensor looks suspiciously like a Harley one, Anyone know?"
The Harley sensors are shorter so will not fit....its a bespoke S&S part....
If it was a sudden engine cut then I would also agree to faulty crank sensor (which will also give symptoms of a faulty fuel pump) but change the fuel pump regardless as it is worthwhile doing so.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
If it was a sudden engine cut then I would also agree to faulty crank sensor (which will also give symptoms of a faulty fuel pump) but change the fuel pump regardless as it is worthwhile doing so. I agree change the fuel pump or you will regret not doing so.
Posts: 60 |
I had the same problem on and after replacing many parts it turned out to be the Crank Position Sensor. It is a different engine to yours but when I went to the agent of the engine to order the part he asked me for Euros200 but I bought the same part by the same manufacturer for euros40. Very often these sensors are used on different cars so it might be worth checking that. If I am not mistaken I think there is a thread with a list of parts on Talkmorgan where you can find the same replacement part and the car it is used on. I spent a lot of time and money to fix the fault but at least I now know my trike much better. Phase sensor faults could be intermittent and could prove very dangerous on the road
Posts: 592 |
Hi guys, thanks for all your input, done nothing as yet other than the purchase of a Walpro pump and also a US Pro fuel pump pressure testing kit off eBay, an absolute bargain at less than £25. The Factory are adamant that it is the Crank position sensor but have none in stock. My idea was to drive the car until it stopped then change the sensor at the side of the road as opposed to having to change the fuel pump. The sensor looks suspiciously like a Harley one, Anyone know? Thanks in advance....... I have the same pressure testing kit, mine didn’t come with the right size Schraeder adaptor, did you manage to locate one?
M3W Brooklands (2015) Moody 41 (2013)
Posts: 698 Likes: 7
Toys for Boys Talk Morgan Regular
Posts: 698 Likes: 7 |
I had the same problem on and after replacing many parts it turned out to be the Crank Position Sensor. It is a different engine to yours but when I went to the agent of the engine to order the part he asked me for Euros200 but I bought the same part by the same manufacturer for euros40. Very often these sensors are used on different cars so it might be worth checking that. If I am not mistaken I think there is a thread with a list of parts on Talkmorgan where you can find the same replacement part and the car it is used on. I spent a lot of time and money to fix the fault but at least I now know my trike much better. Phase sensor faults could be intermittent and could prove very dangerous on the road If anyone has a source or a compatible alternative part for an X-Wedge Crank Position sensor then please let me know, as I have need of one.
Omne trium perfectum
Posts: 60 |
Probably it’s the same one used by Harley Davidson. If you go on eBay I am sure you will find the required part
Probably it’s the same one used by Harley Davidson. If you go on eBay I am sure you will find the required part I would love to be proved wrong but I think in this case the CPS is unique to the X-Wedge. The Harley ones unfortunately won't fit because they are around 10mm too short. I'll start a new thread to see if we can track down an alternative.
Andy
