10 members (John Wilcox, Arwyn Williams, gomog, Plus Four Guy, AlyMatt, jbk, Sir Percival, TalkMorgan, JohnHarris, Saxman1964), 226 guests, and 34 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
Page 4 of 4 1 2 3 4
Ken F #744743 15/06/22 06:38 PM
Looking good Mike
Ken F #744783 15/06/22 09:55 PM
Thanks for the info Mike, I've squirrelled it away.
Oddly, I thought your breakages were going to be at the prong area 'cos there's a lot of friction to be dealt with there. So, thanks for advising this potential problem and fix.
Are you taking orders 'cos it looks very professional?!
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Ken F #745002 17/06/22 10:12 PM
At first I made the plates from 3mm thick aluminium thinking that that would add strength, but realised that the surface of the rail isn't flat, but profiled (or maybe uneven is a better word), so I used 1mm steel so it will take the shape of the surface when all tightened up. The original fixing screws are 6mm, I used 5mm for the screws that fix the plate to the rear part of the rail so as not to weaken the rail too much.
So I can always supply a drawing/template as I have a set in aluminium
Decided to buy a stapler which uses 140 staples (10mm flat crown) to fit the cloth trim back in place. and unibond repair extreme power glue to stick the rubber back to the rail
Mike Smith
2007 +4
Page 4 of 4 1 2 3 4
