13 members (Sir Percival, MogOnTheMove, MATTMOG, LE52MOG, Morganmike, Burgundymog, GrandadC, John V6, TBM, Richardllll, Rex_tulips, PaulyG, Adam12),
345
42
New
Topics48,365
Posts813,388
Members9,215
Posts: 2,794 Likes: 161
Posts: 2,794 Likes: 161 |
https://www.sportseats4u.co.uk/prod...seats/morgan-plus-8-classic-sport-seats/ These guys offer a more up-to-date seat option and you could spec the leather cover option for about £650 a seat may be cheaper than recovering a second hand seat or the existing seat.
Prev '12 Plus 4 Sport OZZY '08 Roadster FELIX '06 4/4 70th LOKI '77 4/4 SEAMUS '85 4/4 MOLLY
Posts: 1,384 Likes: 56
Posts: 1,384 Likes: 56 |
They don't recline, seen them before. cheers Gary
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
Gary These look better, but may be limited with trim options Corbeau
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
The trim shop at Allon White's used to offer the option of new recliners or mods to your existing seats, may be worth a chat with Shaun
The Corbeaus work out at almost £1000 each and yes AW will offer correct new recliners at approx £3500 per pair.
Either would be fine but the price is eye-watering especially after adding the rest of the interior trim. So £3500 for something aftermarket looking or £5000 for something genuine looking.
Hence my dithering dilemma
5K on interior, £2k at tornado and another £2k on paint (still no easy hood remember) or put the £10k into a newer car?
But there’s also the option I used last time - do nothing and keep dithering!
Posts: 193 Likes: 5
Posts: 193 Likes: 5 |
This is often the best solution.
Posts: 3,581 Likes: 85
Posts: 3,581 Likes: 85 |
You need to find a 4-seater being broken or perhaps do a swap deal with a 4-seater owner! Sorry, not me though. I can't say I recline my seats often but it's nice to have the choice.
Re the seats that recline
I’ve bought and tried to adapt MX5 seats. I managed to adapt the seat base by cutting it up and welding it back together 4 inches narrower, I even managed to chop up some foam to make a base to sit on. It was much too high though. MGF seats are wider and taller but more comfortable.
The seat back on the MX5 was far too wide but very difficult to modify as the steel frame is moulded into the foam. Easy enough to cut up but not possible to weld back together due to the fire risk.
One of the problems is that almost uniquely, Morgan seats are thinner at the front, ie they taper forwards. Almost every seat I’ve seen tapers to the rear and are wider at the front. Another is that Morgan seats are very shallow, I would estimate the average bum is not more than an inch above the cockpit floor. Most of the seats I’ve seen are much higher than this.
Thanks for the thoughts though, I’m still dithering.
You need to find a 4-seater being broken or perhaps do a swap deal with a 4-seater owner! Sorry, not me though. I can't say I recline my seats often but it's nice to have the choice. My problem is that I’m oddly proportioned and have rather short legs so my seat position is usually quite far forward but my body and arms are more sensible dimensions to I drive with my seat well reclined to get comfortable. I’ve driven like this for over 40 years and any other position doesn’t feel ‘right’. I’ve found a compromise with my car using wooden wedges under the seat that tilt the whole seat back, lifting the front. It’s better but not ideal. Nowhere near as comfortable as a normal car or the car I went to see a couple of weeks ago (linked above)
Posts: 35,796 Likes: 474
Posts: 35,796 Likes: 474 |
Just go for the newer comfortable car and be ready to hardwire the mickey mouse dash electrics if necessary as per Borghi  Avoid the GDI unless you want to chuck money at it finishing what MMC should have done before they flogged them, as per Dave's statement.
