0 members (),
229
94
Topics49,847
Posts837,389
Posts: 2,086 Likes: 70
Posts: 2,086 Likes: 70 |
I received an email from the Morgan Sports Car Club that said inter alia:
I wish to take this opportunity to address a misleading rumour that has been circulating, to which some of you referred in your responses: a report that the defective component was made in India. We were told that this is NOT the case: it was made by a reputable UK supplier.
So how does that tally with the message my friend sent me for his plus four, as follows: “Out of interest I have just taken down all the Makers info off the Brake servo and pump cylinder. Exactly as Printed on the servo, it reads: “trenos IRUNA BRAKES/ REF PROVEEDOR 6107095/MADE in CEE LOTE No 1100.” On the master cylinder body it reads “LB095L 007A”. Doesn’t look very British to me!
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
It says "reputable UK supplier" which could mean a reputable company that supplies the UK, rather than a UK company?
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
So how does that tally with the message my friend sent me for his plus four, as follows: “Out of interest I have just taken down all the Makers info off the Brake servo and pump cylinder. Exactly as Printed on the servo, it reads: “trenos IRUNA BRAKES/ REF PROVEEDOR 6107095/MADE in CEE LOTE No 1100.” On the master cylinder body it reads “LB095L 007A”. Doesn’t look very British to me! Cee is a town in Spain. Lote means batch in English, according to Google translate
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
More likely is old tooling and means Comunità economica europea (CEE) See https://irunabrakes.com/company/
Iruna are well known for their boosters and servos (and are fitted to a lot of vehicles) and as far as I'm aware there are no issues with the servo. I wonder if the 'LB' code on the master cylinder stands for 'Lucas Braking'? Lucas still exist under the TRW banner. That would tie in with the UK supplier bit?
I am with TBM & Gambalunga on this. I think any “Lucas” stuff uses the TRW logo.
Posts: 33 |
Posts: 63 |
Nah, ‘LB’ means ‘loose bowels’.
S3 Roadster Brooklands LE 3/50.
Posts: 16 |
I think you will find CEE is a collective name of the old Eastern European Block of the former Soviet Union
I think you will find CEE is a collective name of the old Eastern European Block of the former Soviet Union When EEC is written in French/Spanish is becomes CEE. Buy La Directive 85/374/CEE relative à la responsabilité du fait des produits: dix ans après = Directive 85/374/EEC on product liability : ten years after ...
