8 members (Hamwich, Ian Wegg, banbury, Lance, Morganmike, rossocorsa, dogmog, Soleng),
257
44
Topics49,914
Posts838,188
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
Where exactly can I find the starter relay on a 1994 +8? Thanks.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
It ought to be not far from starter itself as the piggy back solenoid takes a fair current. Trace the thinner wire from this solenoid (should be red/white) and it will take you to the relay.
Posts: 27,849 Likes: 767
Posts: 27,849 Likes: 767 |
On the early Roadster they are behind the dash on the drivers side at the top of the bulk head. Your might be similar
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
The relay should be under the bonnet, on the offside, just screwed to the bulkhead, up above the starter motor/brake master cylinder. about the same height level as the steering column. In my case its just a standard black plastic cased relay.
--------------------------- Mike Smith
2007 +4
Posts: 310 Likes: 9
Thanks for that Mike, spot on. Mine is a black relay as well. 👍
