Topics48,341
Posts812,981
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
Where exactly can I find the starter relay on a 1994 +8? Thanks.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 7,920 Likes: 216
Posts: 7,920 Likes: 216 |
It ought to be not far from starter itself as the piggy back solenoid takes a fair current. Trace the thinner wire from this solenoid (should be red/white) and it will take you to the relay.
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
On the early Roadster they are behind the dash on the drivers side at the top of the bulk head. Your might be similar
Posts: 310 |
The relay should be under the bonnet, on the offside, just screwed to the bulkhead, up above the starter motor/brake master cylinder. about the same height level as the steering column. In my case its just a standard black plastic cased relay.
--------------------------- Mike Smith
2007 +4
Posts: 296 Likes: 4
Thanks for that Mike, spot on. Mine is a black relay as well. 👍
