7 members (+8Rich, Hamwich, RichardV6, Fuel.inj, Barkingdog, John V6, bmgermany), 204 guests, and 51 robots.
+8Rich 83
Topics49,860
Posts837,491
Jonny72
#744939 17/06/22 08:37 AM
MogCX Offline OP
While my car is off the road I thought I'd investigate the weak heater output before it gets too hot to test it.
The heater in my Plus Four resolutely refuses to blow hot air until the engine has run for at least 5 minutes, and then only when at high revs. Allowing the engine to idle cuts the heat almost instantly; almost as if there is some valve redirecting coolant from the heater matrix elsewhere. Are other owners seeing similar properties? My dealer has helpfully explained that TADTS.
MogCX #744941 17/06/22 08:52 AM
Engine coolant thermostat stuck open perhaps..?
MogCX #744958 17/06/22 12:29 PM
The priority is to heat the engine when it is cold. The heater works well when the engine is warm.
I have the same thing on mine.
MogCX #744966 17/06/22 02:51 PM
Smile, it confuses them
I would imagine this is down to the emission engineering ?
Most modern cars aim to get the engine up to temperature as quickly as possible so they can manage the emissions and during this phase it might be keeping the hot water within the engine loop? If the AirCon in a big BM is setup correctly it may supplement this to give you heat through an electric element?
Just boot it a bit more innocent
MogCX #745459 22/06/22 09:20 AM
My lower vents are useless. Blow little air ever.
MogCX #745465 22/06/22 09:57 AM
I find my plus 6 very poor compared the trad heater.
Mike
1982 4/4
1999 +4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
MogCX #745471 22/06/22 10:51 AM
MogCX
Yes I have exactly the same issue. I have raised it with my dealer while the car is still under warranty (just) so hopefully they can do something about it. Roger
MogCX #745480 22/06/22 01:03 PM
Pre CX heater comparison.
20 year old 4/4 heater;
Driver’s left foot and lower leg roasting.
Passenger’s right foot and lower leg roasting.
All other parts of the body unaffected.
Bud
4/4 - Stanley
budster
Bud
4/4 "Stanley"
MogCX #745490 22/06/22 03:23 PM
The first CX cars had wondeful air to the dash vents but no physical pipe connection to the footwells, they must have assumed air would find it's way down there, it didn't. The first fix was 3D printed parts to direct the air, that was better but definitety feeble even with the dash vents closed. I haven't felt any improvement on later cars so that seems to be as good as it gets.
MogCX #745524 22/06/22 07:04 PM
Plus 6 has heated seats also - not sure if they were an option.
2016 Carmine Red 991.2 C4S
