6 members (JMcL, Luddite, Franko, IcePack, jbk, Mogdavid), 329 guests, and 34 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,916
Posts838,221
MossyfromNZ
#746310 29/06/22 03:28 AM
PaulyG Offline OP
When I press on the brake pedal the brake lights work fine. However, when the headlights are on and I press the brake pedal, one brake light gets brighter, and the other goes off. It's only a problem when I have the headlights on.
Any idea where to start looking?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #746313 29/06/22 06:02 AM
TBM Offline
I'd start with the earths. I've had some really wierd stuff happen due to earth issues!
PaulyG #746316 29/06/22 06:17 AM
That's a good one! Putting the headlights on would also turn on rear sidelights. Check all associated rear wiring particularly shared ground connections as it looks like issue is being caused by unintended electrical secondary paths.
PaulyG #746324 29/06/22 08:33 AM
Black Rat
Black Rat
Probably a faulty side light bulb, start by putting some new bulbs in. I f your brake light bulbs are dual filament it's probably one of them.
Keith
2013 narrow bodied + 4 Ruby.
PaulyG #746332 29/06/22 11:34 AM
PaulyG Offline OP
I will look at the earths. I think I have to pull the spare out to find the connections.
I did test the bulbs with an Ohm meter and they checked out OK, but I thought I would change them first since that is the easiest thing to do.
73 4/4 "Henry A"
60 MGA
PaulyG #746337 29/06/22 12:20 PM
TBM Offline
My money is that it's the opposite light to the one that's doing wierd stuff - possibly a bullet pulled out of a connector......
PaulyG #746338 29/06/22 12:22 PM
Could be the connection in the bulb holder even if the bulbs check out fine off the car .... cleaning the solder contacts on the bulb bases and the sprung pins in the holders is never wasted time.
PaulyG #746339 29/06/22 12:31 PM
PaulyG Offline OP
The bulb connections looked fine.
I have to locate the bullet connections. Not sure if they are under the spare, or under the boot.
73 4/4 "Henry A"
60 MGA
PaulyG #746445 30/06/22 12:54 PM
PaulyG Offline OP
I replaced the bulbs and inspected the sockets. All good.
I checked all the connections in the rear of the car and everything seems fine there. And all the Earth's look good to. I checked ohm readings from earth in the socket to the frame and that is good.
When I have both bulbs out I checked the sockets with a meter, and everything there is working properly.
The issue is when the side lights are on and the brake pedal is pushed. It must be a problem with one wire somewhere, but I haven't found it yet
73 4/4 "Henry A"
60 MGA
PaulyG #746447 30/06/22 01:10 PM
Could it be your hydraulic Brake light switch, checked earthing there?
Example, pics and all sorts.
https://www.gomog.com/allmorgan/brakelightswitch.html
ABBO
Morgan 2005 Roadster
Morgan 1986 4/4 4str Prev
Morgan 1953 +4 DHC Prev
Flippin Pongo 3008 Hybrid
