Topics49,919
Posts838,267
Posts: 812 Likes: 60
Posts: 812 Likes: 60 |
When I press on the brake pedal the brake lights work fine. However, when the headlights are on and I press the brake pedal, one brake light gets brighter, and the other goes off. It's only a problem when I have the headlights on.
Any idea where to start looking?
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
I'd start with the earths. I've had some really wierd stuff happen due to earth issues!
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
That's a good one! Putting the headlights on would also turn on rear sidelights. Check all associated rear wiring particularly shared ground connections as it looks like issue is being caused by unintended electrical secondary paths.
Posts: 5,443 Likes: 133
Black Rat Charter Member
Posts: 5,443 Likes: 133 |
Probably a faulty side light bulb, start by putting some new bulbs in. I f your brake light bulbs are dual filament it's probably one of them.
I will look at the earths. I think I have to pull the spare out to find the connections.
I did test the bulbs with an Ohm meter and they checked out OK, but I thought I would change them first since that is the easiest thing to do.
My money is that it's the opposite light to the one that's doing wierd stuff - possibly a bullet pulled out of a connector......
Posts: 5,608 Likes: 617
Posts: 5,608 Likes: 617 |
Could be the connection in the bulb holder even if the bulbs check out fine off the car .... cleaning the solder contacts on the bulb bases and the sprung pins in the holders is never wasted time.
The bulb connections looked fine.
I have to locate the bullet connections. Not sure if they are under the spare, or under the boot.
I replaced the bulbs and inspected the sockets. All good.
I checked all the connections in the rear of the car and everything seems fine there. And all the Earth's look good to. I checked ohm readings from earth in the socket to the frame and that is good.
When I have both bulbs out I checked the sockets with a meter, and everything there is working properly.
The issue is when the side lights are on and the brake pedal is pushed. It must be a problem with one wire somewhere, but I haven't found it yet
Posts: 82 |
Could it be your hydraulic Brake light switch, checked earthing there? Example, pics and all sorts. https://www.gomog.com/allmorgan/brakelightswitch.html
ABBO Morgan 2005 Roadster Morgan 1986 4/4 4str Prev Morgan 1953 +4 DHC Prev Flippin Pongo 3008 Hybrid
