0 members (), 313 guests, and 32 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Dek Offline OP
Hello
Is there a fuel filter on a 2010 Duratec Plus 4 and if so, where is it?
Thanks
Derek
Duratec Plus 4 yes. Filter behind tank. Cylindrical, held by single clamp, connections each end. Part # MPS0952
Motorcraft Part FG986B
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
In case anyone is unaware….you need to depressurise the fuel system before changing the filter.
1. Open fuel filler cap
2. Start engine
3. remove fuse for fuel pump
4. wait until engine stops running due to running out of fuel
5. Remove & replace filter
6.Replace fuse, filler cap, turn on ignition and allow pump to prime, start engine. Check for leaks.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Dek Offline OP
Thanks for the advice. I forgot to mention that she is a 4 seater. Does that make a difference? "Behind the tank", does that mean on the rear of the vehicle side of the tank? Thanks.
I have never looked closely at a 4 seater, but if like the two seater, would guess that if you remove the spare wheel, you should see it between you and the fuel tank.It’s about 50mm diameter, clamped horizontally and may be coated with underseal.
Doug
1958 Triton 650
Dek Offline OP
Thanks
