6 members (Oliemog, Graham, G4FUJ, Colin_Mackay, Julian BB, BobtheTrain, CooperMan),
123
42
Topics49,911
Posts838,142
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
BTW the fluid is almost clear No obvious contamination
After some further research I found this: The color of the DOT 4 brake fluid is almost mineral clear with a little composition of yellow. It is compatible with DOT 3 and DOT 5.1.
Looks just like what's in the reservoirs.
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 327 |
Sounds like you're not sure if/when/what......i would get a couple of litres of Dot 4 and and push it through the full hydraulic system, both the clutch and brake circuits then you know where you are. Job done for 2 yeas
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
I stand to be shot down in flames but here goes……..
Dot 5 is purple so really there should not be a problem deducing what’s in your system. But my understanding is the purple colour is not permanent and after a few years the fluid will be more of an amber colour.
Hence, why people do the “water test”!
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Whatever you do, I always affix a small label (dymo type of thing) on all fluid reservoirs including coolant, showing exactly what’s in there and date changed, for future use.
Posts: 159 Likes: 1
Great idea. I keep al that information in Notes on my iPhone and Mac laptop. But the labels are a good way to make sure..
Posts: 5,472 Likes: 476
Posts: 5,472 Likes: 476 |
I did not note that Automec SBG DOT 5 hydraulic fluid as being an obviously different colour from any other brake fluid I have used over the years. Included in the box containing the fluid bottle is a flexible plastic lable advising that the fluid contained therein is DOT 5. The lable a hole through it to enable it to be fixed to the fluid resevoir with a zip tie, which is also provided.
