10 members (JohnHarris, JMcL, IcePack, John V6, Burgundymog, RichardV6, Vansrv6, bmgermany, Luddite, Colin_Mackay), 288 guests, and 27 robots.
+8Rich 96
John V6 50
Topics49,899
Posts838,029
Dutch #747857 13/07/22 10:20 PM
Dutch Offline OP
BTW the fluid is almost clear No obvious contamination
After some further research I found this: The color of the DOT 4 brake fluid is almost mineral clear with a little composition of yellow. It is compatible with DOT 3 and DOT 5.1.
Looks just like what's in the reservoirs.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #747866 14/07/22 05:00 AM
Sounds like you're not sure if/when/what......i would get a couple of litres of Dot 4 and and push it through the full hydraulic system, both the clutch and brake circuits then you know where you are. Job done for 2 yeas
Dutch #748048 14/07/22 09:58 PM
I stand to be shot down in flames but here goes……..
Dot 5 is purple so really there should not be a problem deducing what’s in your system.
But my understanding is the purple colour is not permanent and after a few years the fluid will be more of an amber colour.
Hence, why people do the “water test”!
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Dutch #748055 15/07/22 06:43 AM
Whatever you do, I always affix a small label (dymo type of thing) on all fluid reservoirs including coolant, showing exactly what’s in there and date changed, for future use.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #748130 15/07/22 03:50 PM
Dutch Offline OP
Great idea. I keep al that information in Notes on my iPhone and Mac laptop. But the labels are a good way to make sure..
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Dutch #748183 16/07/22 05:29 AM
I did not note that Automec SBG DOT 5 hydraulic fluid as being an obviously different colour from any other brake fluid I have used over the years.
Included in the box containing the fluid bottle is a flexible plastic lable advising that the fluid contained therein is DOT 5. The lable a hole through it to enable it to be fixed to the fluid resevoir with a zip tie, which is also provided.
