Topics49,871
Posts837,685
Posts: 44 |
I have a Morgan Plus4 2005 and would like to tidy under dash on passenger side. Currently there is a large piece of rubber held by cable ties. It is ripped in a few places- can a replacement piece be bought alo what is it called? Many thanks
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
I don't think you can buy it but you can buy sheet rubber (I worked in the rubber industry so no jokes about being big in industrial rubber). I took mine off before the transit bent my S1 Roadster. I might still have it , I'll let you know.
Also a good neeoprene glue & some patches should work
Posts: 44 |
Thank you for your advice. Regards
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Try a trim supplier like Woolies. They sell rubber sheet material in various thicknesses. https://www.woolies-trim.co.uk/Sold by the metre so you will get plenty! Gulp! £57 for 1/4” . Prices have gone up!
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
What is the purpose of the rubber sheet? A cleaner look? of heat control?
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
What is the purpose of the rubber sheet? A cleaner look? of heat control? Just a cleaner look & sort of stops errant cables gradually sagging onto the passenger legs, it's actually not a bad material to use because at least it doesn't rattle
Posts: 44 |
Posts: 172 |
Try a trim supplier like Woolies. They sell rubber sheet material in various thicknesses. https://www.woolies-trim.co.uk/Sold by the metre so you will get plenty! Gulp! £57 for 1/4” . Prices have gone up! Suggest you have a look at the trim to size "rubber" car mats in your local B&M store, around £12 a set.
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
I wouldn't bother with it. Just make sure the cables are sufficiently tied up so as not to drop as in a post above.
Posts: 44 |
Thanks for your responses I’ll have a think- maybe somebody has an odd piece lying around that I could purchase.
