8 members (Jon G4LJW, MATTMOG, Luddite, Tom Sayles, Hamwich, DCH, Davetherave, RedThree), 207 guests, and 126 robots.
+8Rich 78
Topics49,872
Posts837,687
Rudolf
#747959 14/07/22 01:06 PM
I have a Morgan Plus4 2005 and would like to tidy under dash on passenger side.
Currently there is a large piece of rubber held by cable ties.
It is ripped in a few places- can a replacement piece be bought alo what is it called?
Many thanks
Gilberto #748016 14/07/22 06:31 PM
I don't think you can buy it but you can buy sheet rubber (I worked in the rubber industry so no jokes about being big in industrial rubber).
I took mine off before the transit bent my S1 Roadster. I might still have it , I'll let you know.
Also a good neeoprene glue & some patches should work
John V6 #748017 14/07/22 06:33 PM
Thank you for your advice.
Regards
Gilberto #748018 14/07/22 06:33 PM
Try a trim supplier like Woolies. They sell rubber sheet material in various thicknesses.
https://www.woolies-trim.co.uk/
Sold by the metre so you will get plenty!
Gulp! £57 for 1/4” . Prices have gone up!
Gilberto #748022 14/07/22 06:56 PM
What is the purpose of the rubber sheet? A cleaner look? of heat control?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #748024 14/07/22 07:28 PM
Just a cleaner look & sort of stops errant cables gradually sagging onto the passenger legs, it's actually not a bad material to use because at least it doesn't rattle
CooperMan #748032 14/07/22 08:23 PM
Thanks all
sospan #748042 14/07/22 09:22 PM
Suggest you have a look at the trim to size "rubber" car mats in your local B&M store, around £12 a set.
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
Gilberto #748064 15/07/22 07:38 AM
I wouldn't bother with it. Just make sure the cables are sufficiently tied up so as not to drop as in a post above.
Graham, G4FUJ #748088 15/07/22 10:45 AM
Thanks for your responses I’ll have a think- maybe somebody has an odd piece lying around that I could purchase.
