8 members (GrumpyPa, meabh, Mog on Island, xc68anc, Lordofthewings, Image, Graham, G4FUJ, RedThree),
294
33
Topics48,349
Posts813,103
Members9,212
Posts: 4,609 Likes: 193
Posts: 4,609 Likes: 193 |
That is super annoying, I recall you replacing a battery on one of them not so very long ago. The charging thing has reminded me of PJ's car and it seems likely that he had current leakage on his possibly due to a loom fault. He has had repeated battery failures if I recall correctly. Good luck with the starting and recommissioning. The Aero's seem a little like marrying a super model, expensive to run with a few flaws- but WOW when they are up and running  An unfortunate aspect in terms of evolution in vehicle design seems to be that many modern vehicles especially those rarely used, place demands on their batteries causing all sorts of frustrations which can be off-set by making use of a float charger, oft times permanently connected.. However such seems to be the complexity of vehicle systems that intermittent faults in soft or hardware can cause varying degrees of discharge over time when the vehicle is not in use. Ideally a digitally controlled float charger should be able to compensate for these losses, though being a sophisticated bit of kit it`s self, a charger/conditioner is not immune from possible failings....? With intermittent faults relative to battery discharge I hesitate to suggest adding another layer of digital technology in an attempt to assist condition monitoring and assessment, But..? Apologies if it has been mentioned before. https://youtu.be/AB9YN0DY6ZkPerhaps also worth noting and has been mentioned previously, is that AGM batteries hove higher fully charged voltages than non-AGM old style batteries and thus require a float charger more suited to their specific requirements.
Posts: 2,793 Likes: 161
Posts: 2,793 Likes: 161 |
Never seen the point of tyre sensors, when they fail they can be a pain to replace with constant error messages and once activated can be a pain to deactivate when scrolling thru less used pages of options in the command system, that are never intuitive (well to me they aren't). Once a handbook gets beyond the size of War and Peace you know you are in trouble, I think it was about page 30 before I found how to start the engine!
Prev '12 Plus 4 Sport OZZY '08 Roadster FELIX '06 4/4 70th LOKI '77 4/4 SEAMUS '85 4/4 MOLLY
Posts: 5,224 Likes: 123
Posts: 5,224 Likes: 123 |
Once a handbook gets beyond the size of War and Peace you know you are in trouble, I think it was about page 30 before I found how to start the engine! Even printed handbooks are going away. The instructions for the Sat-Nav built into Mrs F’s Mini Clubman are built into the device. It refuses access to the instructions whilst the vehicle is moving - which means that the passenger has to request a halt in progress in order to understand the tortuous menu system.
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
John the tyre sensors come in several forms now.
The older ones which were using pressure sensors as fitted to the early Aeros were all you mention. So many now just dis-connected.
The newer ones seem to use the ABS sensors (like every seems to these days) and use the rotation speed to establish the pressure. Amazing that they can deduce it to that accuracy through this. On my Audi before and now on the ML it shows the pressures based on this. It has been very accurate and unlike the older ones no hassle.
I always say that if you need a manual you have not designed the product correctly. Now it seems that the manual is mostly there to carry the warnings and legal dispensation stuff. As Paul comments the access to the on-line manual is also annoying. No doubt it will also become a paid for subscription shortly. Access and updates in line with the software updates the car gets will become chargeable!
I have also often wondered if they employee a specific style of deviant to write these things so that they can be translated to multiple languages with least trouble but then become ineffective in all languages?
Posts: 5,046 Likes: 314
Posts: 5,046 Likes: 314 |
As for the ABS tyre sensing ... I guess after you've driven a mile it's had plenty of samples to average out .
The wife fancies a change and looking at replacing her Mercedes Cabriolet (nothing wrong with the current one, only done 33k miles and in very nice condition). So we sat in a new E class then the C class, and test drove the E class. The salesman gave me the key, with a few simple instructions and left us to it, a good five minutes later and we still couldn't find how to start the car, let alone put the hood down and I've had 6 Mercedes cabriolets since the early 90's. I gave up and went and got the salesmen. It was not at all obvious, so goodness knows how we would get on with the latest command systems, even with a hard copy manual......................we hardly use any of the current car's options via the command system and we just seemed to allow simple things like electric memory seats start to determine our purchase criteria.
I'm increasingly looking at keeping the current car, we are both comfortable with, well maintain and less to go wrong.
Posts: 7,901 Likes: 241
Posts: 7,901 Likes: 241 |
Once a handbook gets beyond the size of War and Peace you know you are in trouble, I think it was about page 30 before I found how to start the engine! Even printed handbooks are going away. The instructions for the Sat-Nav built into Mrs F’s Mini Clubman are built into the device. It refuses access to the instructions whilst the vehicle is moving - which means that the passenger has to request a halt in progress in order to understand the tortuous menu system. I wonder which bright spark in the software dept thought of that, without testing all eventualities
Posts: 5,883 Likes: 20
Posts: 5,883 Likes: 20 |
No different to your computer software when you pay extra to have an extra facility turned on. Or the Sky box for example.Makes a lot of sense since the heating in both seat and wheel is trivial in cost to include on every car.
Sooner or later there will be a hack on line.
More to the point what this confiorms is that there is a linky between your car and the factory. So instead of linking up a lappie at service time your car is plugged directly into the mainframe at the factory who can download all the faults / history etc. Its the same with Merc and other brands.
Posts: 359 Likes: 8
Posts: 359 Likes: 8 |
Admittedly an old data point but the abs tyre pressure sensor system on a 2009 Scrirocco failed to pick up a blown side wall in the 500m or so that it took my wife to get from the fast lane of the M4 to the hard shoulder (they had them in those days...) after she hit something dropped by a truck....
