8 members (Bilymog, linklaw, DavidR, Strathaven, Bunny, Graham, G4FUJ, lez, TalkMorgan), 184 guests, and 36 robots.
+8Rich 99
John V6 55
Topics49,906
Posts838,104
Page 3 of 7 1 2 3 4 5 6 7
Abbo Offline OP
Bored of me yet! i keep thinking of stuff, that could be relevent and found TM Image!
To answer whether they were crafted for left and right, I doubt it, Neale said to put the higher one (5-6mm difference) on the drivers side.
All lubed up a good few days before fitting etc.. Shackles and bolts cleaned.
ABBO
Morgan 2005 Roadster
Morgan 1986 4/4 4str Prev
Morgan 1953 +4 DHC Prev
Flippin Pongo 3008 Hybrid
Rog Offline
Originally Posted by Abbo
That’s quite a bit of difference! There is little that can go wrong with the installation and if the car was not that bad before the change then I would have chat a with Mulfab and show them that rear end pic. It’s not inconceivable that there is an issue with the new springs, maybe the crimping of the rebound clips or something? One other possible thought is how different is the camber on the old springs? It could be that somebody originally fitted springs with different cambers to offset an original build issue maybe.
Roger
Abbo Offline OP
Rog, taken before the great pandemic, little mileage since.
I did compare old and new, same camber. old ones were the originals, I assume +8 old stock.
Rebound clips, as in the clamps around the srings holding them in place?
I will definetly give MulFab a shout.
looks fairly level june 22 I would have noticed long before, I have OCD when its this car!
I have since put the jubilee wall covering up LOL
Thanks, Paul
ABBO
Abbo Offline OP
Rog, old leaf springs
ABBO
I am no expert in anyway, but are you implying in that pic that the axle isn't level?
It may not be possible, but I would be inclined to jack the car up on both sides so it is level, then see how the axle lies, assuming it is not sitting on the chassis.
1956 Plus 4 4 seater
Rog Offline
Yes re the clips Paul. What is the front like? Perhaps a sticky pin maybe, still on those original plastic bushes? If you jack in the centre at the front is the rear still twisted?
Roger
Abbo Offline OP
The axle is level. It’s the body that is on the P. One side of the axle is the right height from the bump stop, the other is on the chassis bump stop, thus I believe forcing the O/S higher.
I could simply be looking at a naff spring, that has not enough oomph to raise the axle.
ABBO
Abbo Offline OP
I had SSL fitted a couple of years back part of my endeavour to make the ride a little more comfortable for my wife. New Chrome pins, new bushes, springs etc. so no devol
I shall spend another evening in the garage, whip the front up, check out the twist; should please the my wife, spending yet another evening on my other love interest!
ABBO
So swapping the springs left to right would resolve the chassis versus spring ambiguity or not ?
Abbo Offline OP
Blimey Richard, that’s a tall order, just to check, I'm sweating already at the thought however it is cause for thought
ABBO
